Question about Leviton 6124H 24 Hour LCD Programmable Decora Electronic Incandescent / Ind
6124H no display
No display
  • 102 Answers
Cheaper to replace than repair.
Posted on Mar 10, 2009
Programing instructions
you can look here http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=6124H-I&section=44955&minisite=10251 and click the adobe manual for programming instructions.
May 05, 2012 | Leviton 6124H 24 Hour LCD Programmable...
Hi I have decora 24 hour programmable timer 6124h. Its display seems to be working just fine and I can change the settings on this. But its not turning the load on. Any idea? Much appreciate the help on...
I don't have repair for defective timer.
Check wire nut connection going to load.
Confirm that load is operable and turned on.
See if timer is producing output on blue wire.
Try timer in place of a different switch to see if problem is load or wire going to load, or if timer is defective.
Make sure there are both ON and OFF times programmed.
Check wiring:
Timer blue wire to load.
Timer black wire to hot.
Timer white wire to neutral.
Green to ground.
http://waterheatertimer.org/Leviton-timers-and-manuals.html
Aug 07, 2011 | Leviton 6124H 24 Hour LCD Programmable...
How do i program the LEVITON Decora Timer Light Switch 10/24hrs.
From this website you can download a free instruction sheet in PDF format...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=6216&section=17138
May 12, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
I have a Leviton Decora five button electronic timer.
You need to have a pair of white wires wirenuted and shoved in the back of the box. White to white, black to the hot and blue to the load on the second black. Some of these have a yellow wire for three way connections.
Jan 23, 2010 | Leviton 6124H-I 6124H-I Decora LCD Timer...
Decora 6124H Timer
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Apr 20, 2009 | Leviton 6124H 24 Hour LCD Programmable...
I can't erase the existing programming
I thought I had same problem or that black bars would not erase. It turned out that the switch is sent with a clear decal over the LCD display that makes it look like its on while in the display packaging. I peeled away the decal and everything worked ok.
Mar 16, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Leviton 6124H 24 Hour LCD Programmable Decora Electronic Incandescent / Ind Logo
107 people viewed this question
Top Leviton Hardware & Accessories Experts
Hippy_dd
Gene Haynes
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
