Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater model r100a runs approxamitly 15 to 20 minutes then kicks out.fan seems to run fine and already replaced the spark plug.
  • 232 Answers
Generally if a heater with a spark plug will run for 10 minutes or longer then that’s an indication that the electronics are functioning properly, so for now, eliminate "any fuel delivery problems" before trouble shooting the electronics. The spark plug should spark for the duration of the run time. If the flame goes out the heater shuts down (just like its designed to do). Imagine the fumes & danger involved if the heater continued to pump raw fuel into a hot combustion chamber!
Some possibilities:
  1. the plastic end cover is cracked. When the room heats up the crack expands allowing the air pressure to fluctuate.
  2. the air pump pressure is not correct. (instructions at www.reddyparts.com )
  3. the fuel filter is restricted.
  4. the nozzle is restricted or worn.
  5. there is an air leak between the pump & the nozzle.
  6. water in the fuel. When a droplet passes through there is a momentary flameout condition which will cause the photocell to shut the unit down.
  7. The photocell is defective
Some more troubleshooting tips
Posted on Mar 11, 2009
My Reddy Heater R110 will not fire up. motor runs but doesn't seem to spark. fan runs for a couple minutes then the reset goes off. It has a new spark plug and filter
samsclassics,
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, how to fix it and where to get the parts.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 19, 2011 | Reddy Heater- Variable 75,000-125,000 BTU
I have a Reddy 100,000 btu space heater model R100A. The fan will turn on and the spark plug is igniting, but it does not appear to be getting any fuel so it will not light.
You need to check the nozzle for clogs and also check the fuel filter. Let me know what you find and I will tell you some other things to check.
Dec 29, 2010 | Reddy Heating & Cooling
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Moter run got spark will not go
Set the pump pressure first, then trooubleshoot to see why there is no ignition. Chances once the pressure is set, the heater will run.
Feb 01, 2009 | Heating & Cooling
Heater won't ignite
Moving mine while it was running fouled the spark plug. You can remove the top of the Reddy Heater and access the plug. In my case took less than 10 minutes and it's up and running again. I removed the top and replaced the spark plug. No problems
Jan 24, 2009 | Reddy Heating & Cooling
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
I NEED NEW SPARK PLUG FOR A REDDY HEATER MODEL R100A
You can order it from here.
http://www.desatech.com/product.cgi?products=Construction%20Heaters
I would just pull it out and see if you can get at a local auto supply store first.
Good Luck
Dec 18, 2008 | Heating & Cooling
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
671 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
