Question about HP Office Equipment & Supplies
Long 20 inch plastic was taken out of a HP 1220 C Printer.
What does this plastic strip connect to inside the computer?
  • 24 Answers
This plastic strip is probably the so called "encoder strip", it has many fine black lines that the carriage sensor counts to find out where the carriage is located on the paper.
This encoder strip is attached directly to the printer's frame on the right, and to a leaf spring on the left side. It also runs through a slot on the back side of the carriage.
It can be treaded back and reattached if you're nimble-fingered, but in many cases it's broken and needs to be replaced. As far as I remember HP doesn't sell these parts separately (correct me if I'm wrong!) so if it's broken the printer most probably has to be turned in for service.
But if the encoder strip is intact, there's no right or left side - or up/down - of it, so it can be attached any way you want - as long as you get it back properly. Usually it's best to first hook it up on the leaf spring, then attach it on to the small hook on the right side. Being able to slide the carriage back and forth eases the operation. You can get it back without disassembling the printer; it's fiddly but it's possible.
Good luck! :)
//Al
Posted on Mar 10, 2009
  • kurtz54 Sep 03, 2010
    The encoder strips can be bought separately @ www.partshere.com
Difference between hp printer1200 and hp printer 1220
the only difference it that hp-1220 is with the scanner attached and 1200 is without the scanner.
On the picture posted with the question is HP-1220, remove the scanner and it's talked about HP-1200
Cheers and visit us on //dentaltourusm.rs
Dental practice Mr dr Mirela Cvjetkovic Belgrade Serbia
Mar 28, 2012 | HP LaserJet 1220 Printer
A plastic strip that runs behind the ink cartridges has fallen off. its a quarter inch wide and about 12 inches long. each end has a slot cut at a 45 degree angle and an eigth of an inch from the end. I...
That is the ink guide. If the plastic strip connector (the slot cut on both sides) is not damaged/broken, the other metal tab may have fallen making the plastic strip to fall. It is usually soldered on the metal frame of your printer, find the missing tab and solder it back in. You should find a trace of the tab's original location.
Apr 17, 2010 | HP PSC 750 All-In-One InkJet Printer
I hooked up my 9 year old HP DeskJet 1220 C PS to a new iMac and MacMini and did a test print with the latest Drivers and it work OK. I went to use it the next day, it made a clunky noise and stopped -...
wow.. that is the timing belt and is threaded thru the back side of the ink cartridge assy and is attached at the right and left sides of the carriage assembly.. no way to explain that one.. printer has to be taken apart to the frame and the carriage assembly removed the timing strip re threaded thru the back side and the timing photo sensor and reinstalled.. the timing strip will only go no one way...
Mar 31, 2010 | HP DeskJet 1220c InkJet Printer
My daughter pulled this long plastic strip out HP PSC 1210
Sounds like it is the guide strip that pushes/pulls the print carriage back and forth?
Sorry but it is not a repair easily carried out at home, if at all. If in one piece and not broken it might be re-introduced but the bottom line is you will most likely have to purchase new? Sorry. it might cost just as much if taken to a repairs?
Nov 15, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hi My problem is that this plastic strip has come off of something and now the ink cartridges go back and forth really hard but doesn't print anything. There are little slits on each end of the strip. One...
Hi Debbie,
If the plastic strip is about 10mm (or ~0.4 inches) and about the with of the printer, and if you look very closely the strip is striped (with tiny very think vertical lines).. .that strip is the locator strip… The ink cartridges read that strip to know where the carriage is (ie the carriage reads/counts the strips and then it knows where it is)
Hence if the stripe is now in your possession the printer doesn’t know where the cartridges are and just keeps moving them back and fro hoping to “find them”.. sadly without that stripe you printer will work no more L
Sorry.
Ed
Nov 08, 2009 | HP DeskJet F380 All-In-One Printer
HP LaserJet 1220: all lights are on
Hi
The complete list of the light patterns, causes and what should you do, are there on this link
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=29789&prodTypeId=18972&prodSeriesId=29789&objectID=bpl10633
it looks like this
Type of error Light pattern Recommended action No power - The printer is not connected to a power supply. c00031238.jpg Plug the printer into a power supply.
If the printer lights do not turn on, contact HP. Ready - The printer is ready to print. c00031239.jpg No action is necessary.
To print a configuration/self-test page, press and release the GObutton on the printer control panel. Processing - The printer is receiving or processing data. c00031240.jpg Wait for the job to print.
Oct 20, 2009 | HP LaserJet 1220 Printer
How do I duplicate Calibaration strip on my UMAX
use the guarranty or warranty card ..there is none other solution for this
May 15, 2009 | Umax Astra 610P Flatbed Scanner
Ink light keeps flashing -
Have you made sure that you've taken the plastic strip off of the ink cartridge? I had this problem once and I then realised that i had forgotten to remove the strip covering the ink.
Also, have you installed a colour cartridge? I have the same printer and it wont print unless you have both ink cartridges inserted and in good condition. (If you don't want to fork out for HP Original, I find that the Tesco Remanufactured versions work fine)
Hope this helps.
Joe
Jan 01, 2009 | HP DeskJet 930c InkJet Printer
HP F370 PSC
One possibility is. look toward the back of the printer, there is a strip of clear plastic, about a quarter inch wide and clear. It runs the length of the print head area. That contains the stop strip. That strip or the sensor on the print head itself may be dirty and not sensing the strip, therefor not knowing when to stop.
Mar 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
Jul 03, 2007 | HP DeskJet 5650 InkJet Printer
151 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
