Question about Palm TX Handheld
Hot sync will not synchronize with the calendar
It will synchronize with everything else
  • Anonymous Mar 12, 2009
    I am synchronising using a wireless connection to the server.
    Initially this worked fine and did both calender and e amils now it
    only does the emails
  • Anonymous Mar 26, 2009
    All of a sudden out of nowhere calendar won't synchronize - I use a USB connection
If your device is syncing but getting stuck on calendar it is likely corrupted data that is not allowing the device to synchronize that PIM data.
If you are doing a cabled sync and you are seeing that it is constantly getting stuck on 2 of 12 then this is likely the issue.
This can only be resolved by fixing the corrupted data. To do so you will need the assistance of a third party application calld DBfixit you can find it here
www.pimlicosoftware.com
Set all of your conduits to do nothing and install the trial version on your device. Then run the program. The trial version will tell you what entries are causing this issue and you can manually delete them or fix them. If you purchase the program it will do it automatically for you. Depending on the number of errors you have you may want to purchase the program for the ease factor.
Do try the trial first. Definetly try before you buy.
Posted on Apr 01, 2009
Calendars have disappeared
The likely cause of this problem is that you're synchronizing your iPhone Calendar with iCloud or another online calendar service and your iPhone is set to sync only recent events. This option can be found underMail, Contacts, Calendars in your iPhone Settings app. The default setting is one month, however you can tap on this option and choose from either two weeks, one month, three months or six months or simply choose All Events to sync everything in your calendar.
New events created in the iPhone Calendar outside of this time frame are still saved and synchronized to your online calendar (e.g. iCloud), but once the online calendar has been updated, they are removed from the local iPhone Calendar; hence these events appear to vanish shortly after you've created them. Items you have created on these older dates will actually have been saved in the cloud and you would likely be able to see them on a desktop computer; iCal for Mac, for example, automatically synchronizes all events from iCloud to your desktop calendar, regardless of the setting on your iPhone. Further, if you're using iCloud you can log onto iCloud.com from any web browser and you should see these events in your Calendar there as well. In fact, if you adjust the sync setting above to a longer time frame-or All Events-all of these "lost" events should automatically be synced back down from the cloud and reappear; you'll likely even see all of the instances of events that you tried to create multiple times.
Ultimately, unless you have a very large calendar going back several years, it's probably best to just set your sync events preference to All Events, which will ensure that your entire calendar is available on your device and avoid any future confusion with vanishing events.
Oct 09, 2014 | Apple iPhone 4 Black Smartphone
How do I synch outlook 2003 with iphone
You didn't say whether you're trying to sync everything (mail, calendars, contacts) or just some things or one thing (like contacts only). I don't know if you're using an Exchange server or even if you have the info you'll need to sync with an Exchange server.
I have a Windows mobile device (AT&T Tilt) running Outlook 2007 and everything is sync'd. We also started purchasing the iphone for our employees and sync their email, calendar and contacts to their phone.
I could probably give you step-by-step information (based on how I do this for my users at work) if I knew whether you'll use iTunes to do this or Exchange Active Sync and what you want to sync between your phone and outlook. One method (iTunes) will only update your data between Otulook and the phone when you connect it to the computer with Outlook configured on it but, the way we do it at work, they receive email, data, changes, etc in real time.
Try using this link http://www.apple.com/support/iphone/mail/
What you will find here is support topics and instructions for Exchange Active Sync, setting up email accounts, troubleshooting for contact and calendar syncing.
You can also search support on Apple's Web site. Entering the keywords: iphone outlook 2003 will bring up a lot of support info.
You can use iTunes or MobileMe for synchronization. If using iTunes then try this:
You can configure which items are synchronized during a one time set up process. After initial set up, each time you connect the iphone to your computer, the changes made on your computer or device are synchronized.
  1. Connect your iPhone to your computer. iTunes should open automatically.
  2. In iTunes, in the source list, under Devices, click the entry for your iPhone.
  3. Click the Info tab.
  4. Select which items you would like to sync. For example to sync only calendars, under Calendars, you would click Sync calendars from, and then click Outlook.
  5. Do one of the following:
  • To synch all calendars, click All Calendars.
  • To limit the calendars that are synched, click Selected calendars and then click the calendars you want to sync.
6. Click Apply.
Hope this helps!
Thanks for using Fixya and you can let me know how helpful I've been by rating this solution.
Apr 03, 2009 | Apple iPhone Smartphone
Entourage Hot sync failure with Palm (error = #-1)
1. Right click Red/Blue synch icon in lower right corner
2. Select custom
3. See how many items are in two way synch
Sep 13, 2007 | Microsoft Entourage For Mac for Mac
Treo 650 is not syncing with outlook calendar, but syncing with everything else.
You may have tried Exchange ActiveSync in VersaMail When you setup an Exchange ActiveSync account in VersaMail, you are asking your Treo to synchronize email and your calendar with an Exchance 2003 server. In order to prevent duplicates, VersaMail disables Calendar synchronization via HotSync while the account exists on your Treo. So if you are an Exchange ActiveSync (EAS) user, you have a choice; you either sync wirelessly or you can delete the EAS account in VersaMail and can then sync your Calendar via HotSync. You cannot do both unfortunately.
Sep 12, 2005 | Palm Treo 650 Handheld
Hot Sync with desktop and laptop computers
it is possible but if I well understood u wanna hot sync with ur laptop calendar and contact from ur Tungsten E, (that is having updated data from ur office computer). you can in fact synchronize verything there with ur laptop, and make ur hand held over write ur whatever is in ur laptop, for this u need to install the PDS and go to the hotsync manager on ur system try, go to custom and and on the list of conduits go to contact and change the action to hh overwrite desktop, (do the same for calendar) DON"T FORGET TO CHECK THE OPTION : MAKE AS DEFAULT. U can of course disable the rest except the system conduit. Never forget to set the conduits u change to set as defaults. Like this, u must have always updated data on ur hand-held, for this, u need to keep synchronizing with ur office computer. good luck,
Sep 12, 2005 | Palm Tungsten E Handheld
Calendar Not Syncing
OK. Hope this helps you because it fixed my problem. Go into palm desktop. Go to hot sync, click on custom Go to Calendar (Outlook) and double click on that. At this point click on settings. Under conflict resolution choose "outlook wins". Then go out and check syncronize files and set as default. Click done and this should resolve the issue. Reply if this is confusing.
Outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
Just bought Zire 31 and won't hot sync Outlook Calendar, Contacts, Notes with the following log:
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
Sep 12, 2005 | Palm Zire 31 Handheld
Treo 650 (cingular) and Outlook calendar
Its the substandard conduits that come with the 650. Hi - my issues were different than yours,but similar in that bottom line, my calendar data wasn't syncing correctly with Outlook. I've been dealing with this problem for the past 4 weeks. Sprint's technical support was useless, as was palmone. For 5 years, I have successfully synced my Palm Smart phone to palm desktop at home, and outlook at work - (4 different phones, 4 different companies). It dawned on me - for the past 4 palm devices, I was provided Chapura conduits... The 650 didn't come with them... GUESS WHAT. I bought Chapura Professional XT and all the issues I was having (they were too copious and too weird to go into here) were solved, in one measly synchronization. ALL of them. Don't wast ANY more of your time... Navigate over to Chapura's website and get one of the conduit programs -= trust me... You'll be glad you did.
Sep 11, 2005 | Palm Treo 650 Handheld
MS Outlook syncs calendar, notes but not contacts
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
Sep 11, 2005 | Palm m130 Handheld
Palm TX Handheld Logo
136 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
