Question about Human Touch HT 2620 iJoy Massage Chair
Screwrod broke at base
My ijoy 130 broke at the base where the screw attaches at the little motor. Is there a place I can buy the parts or where can I get it repaired. I thought about taking it to a machine shop and letting them weld it. I could not get the motor to release the point where the rod attaches. thank you, David Switzer
  • 19,396 Answers
You need to call teh manufacturer at the phone number listed on the owner manual.
Posted on Mar 10, 2009
Where can I biuy the plastic gear for ijoy170?
The only place I found information on where to buy parts is on the Human Touch/iJoy site where they simply state:
  • How do I order parts for my chair?
    • For assistance with ordering parts for your chair, please contact a Customer Service Representative by phone at(800) 355-2762 between 6:00 AM and 5:00 PM PDT Monday through Friday. Please make sure to have your Model and Serial Number available when you call in
Human Touch Support Customer Service
Nov 18, 2014 | Human Touch iJoy 170 Robotic Massage Chair...
Replacement Upholstery
I have the same problem. Did you ever find something?
Apr 29, 2013 | Interactive Health Ijoy 130 Massage Chair
I think my magic bullet over heated and now it won't work. I could smell burning plastic and now when I try to use it, it won't blend. Any suggestions. I hate to buy a new one because I don't need all...
The Magic Bullet power base is designed with HIGH TORQUE MOTORS and it is NOT TO BE USED FOR MORE THAN A MINUTE PER USE.Otherwise its gonna last a long time. You need to buy a new one or a refurbished one. Search google with keywords "amazon magic bullet power base".
Oct 15, 2010 | As Seen On TV Magic Bullet Food Processor
How to change the belt?
Yesterday I have the same problem: the belt of my Sunbeam bread machine broke. My problem is I didn't find a belt replacement yet. Once you have a replacement, to change the belt:
1. Unscrew the 4 screws located at the bottom of the machine
2. Open the top of your machine. You'll see 8 screws that put together the bottom of the chamber with the walls. You need to unscrew those screws with a very long screwdriver (caution with the heating element).
3. There is one screw attaching the heat element to a ceramic rectangle to the opposite side of the chamber. Unscrew this TOP scew.
4. Once all those screws are out you have to force the bottom piece of the machine with a flat screwdriver. This bottom is attached to the top part with some clips on the front and the back of the machine.
5. Once you open the bottom "cap", caution when separating both pieces. You will find a flat cable that is connected from the computerized pannel to one card attached to the bottom part of the machine. This plug located on the card at the bottom part of the machine have one drop of glue securing the two parts. Twist off the drop of glue and you can disconnect the cable from the card without any problem.
6. Once both parts (top and bottom) are separated you can proceed unscewing the 7 screws that fix the motor to the plastic bottom "cap". You need to do that to access the bellt area.
7. To place a new belt just unscrew the bolt that fix the large "circle". Take away the bolt, the 2 washers, the rectangle one and the "circle". Place the new belt around the small circle (motor) and the big circle. Return the big circle to its original location (align the square part of the wheel with the square part of the screw) and push it to set it in place. Return the rectangle washer, the flat washer, the pressure washer and screw the bolt to secure the pieces.
8. Put all the pieces together in reverse order: *screw the motor to the bottom plastic piece; *connect the flat cable to the card; *push the top and bottom pieces together and until all the clips fall in place; *screw all the little screws to the botom of the inside chamber; * screw the little/long screw to fix the heat element to the ceramic rectangle; *screw the bottom screws.
Dec 29, 2009 | Sunbeam 5891 Bread Maker
How do I remove the refrigerator base grille
On Kenmore Elite: To remove grill front: Open refrigerator and freezer doors. On the curved (outward) parts of the grille cover, place fingers, and press downward. Grille cover will snap off. Reverse steps to snap back in place.22da2f6.jpg
Aug 06, 2009 | Refrigerators
Just sits and shudders when you push any button except the up and down button
HI, mine started doing the shuddering. It would roll OK, but shudder when the massage part kicked in. I took it apart. There is a plastic gear on the shaft at the bottom of the massage motor. It has a broken tooth. I called the support number for human touch: (800) 355-2762 and they only sell all the mechanical guts as a package for $125.00. I'm still looking for just the gear but am having no luck.
May 16, 2009 | Interactive Health Ijoy 130 Massage Chair
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Human Touch HT 2620 iJoy Massage Chair  Logo
398 people viewed this question
Top Human Touch Health & Beauty Experts
Michael Vincent Cruz
Are you a Human Touch Health and Beauty Expert? Answer questions, earn points and help others
