Question about Canon imageCLASS MF8180C All-In-One Laser Printer
Canon ImageClass MF 8180c Error Code E071
I keep getting the Error Code E071. I keep unplugging and resetting the machine as advised in the owner manual, but still continue to get the same error. I replaced the black cartridge earlier today. Don't know if that had anything to do with it???
Any help is appreciated.
Thanks!
  • imjinnah Apr 03, 2009
    canon color imageclass mf8180c
    system error E071
How to reset setting canon 8180
Posted on Dec 18, 2010
I had the same problem, had to replace the drum unit
Posted on Apr 07, 2009
    Problem Solver:
Canon image class mf6550 error E000
Posted on Dec 14, 2009
CANON IMAGECLASS MF 7460 CODE E000007. HOW DO I RESET THIS MACHINE.
Its because of Fixing film assembly failure its not solving resetting the machine you need to replace fixing film assy
Feb 07, 2013 | Canon imageCLASS D780 All-In-One Laser...
HOW DO I FIX E198-0000 ERROR
CANON MF 8050 - E198 - 0000 ERROR CODE ??
Feb 04, 2013 | Canon ImageClass MF-8050CN Multifunction...
I need driver for my Canon mf 8180c
You can download the drivers for Canon MF8180C from the Official Canon support site and install you printer.
Click here - Click the 'Drivers & Software' - Select the Operating System and you will get the required drivers and software
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 11, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Error message E078 on Canon MF 8100 series after replacing drum
try to check your connection form your printer and if possible try reinstall the printer driver then try to run again the printer.
Jun 16, 2009 | Laser Canon imageCLASS 8180C Multifunction...
Error E078 Canon MF8180c
I have a Canon Color Image Class MF 8180C with a system error code E078 - Trying to understand what it means and how to clear. Any ideas?
Jun 05, 2009 | Laser Canon imageCLASS 8180C Multifunction...
How to fix canon code E071
Here is an answer from DZJOLLA:
"hi there
well ive had years of experience on these machines and seen this error loads so ure in lucksmile.gif
1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
change the connectors mate would be my 1st conclusion for that errorsmile.gif let me know how u go please...
the other errors arent even coming up in the manual which points even more to the connectors.:
Apr 28, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon color imageclass mf8180c, Iam getting '' SYSTEM ERROR E071
I had the same error message E071. Had to call out an engineer who diagnose the Drum 701 was leaking toner - this got on the electrical contacts at the bottom of the drum. He cleaned the contacts on the drum and in the machine - put my old Drum in there and all is OK. The drum was 9 months old and not had much use so I am trying to get a replacement from Canon under warantee.
Apr 06, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon 8180C laser Multi Function printer Error Code 078
did you reset the drum unit on maintanance counter of the machine?
Apr 18, 2008 | Canon MF8180C Color Copier
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
2,380 people viewed this question
old marine
old marine
