Question about NEC DTU 8-1 Corded Phone
Extensions don't ring
After a recent power outage 4 out of our 5 phones no longer ring. How can I get all 5 phones to ring? As a non-profit we need to be able to fix this ourselves. Please help!
  • 149 Answers
4 -12 for riging? MB for ringing is 4-01 day 4-02 night. Do it for all extensions. number all the way to the left when in program mode is the port number. check out ldtsnj.com
Posted on Jun 14, 2009
  • 63 Answers
You will need to access system program mode to change ringing inmemory block 4-12
Posted on Mar 12, 2009
After a power outage, when I am on one line and the 2nd line rings, I hear the ring on line 1 as a loud clicking noise. What could be the problem? Thanks
Check the lines using a hardwired phone plugged into the master sockets, remove any extensions if possible and listen again. Make sure if you have any ADSL filters installed they are removed and the broadband router if you use one.
if the problem persists you'll need to call the Service provider.
Sound like a short issue between the two lines.
Nov 18, 2014 | Lands Phones
After a series of power outages and brown outs over the weekend, our system has lost all of the predialed #'s and only one phone in the whole office (10 phone) rings.
Hello. Often the aftermath of a power outage is a power surge. If your phone system is not surge protected, this is the likely culprit. The damage done by a surge or several surges can only be assessed with a thorough diagnostic exploration. This has to be done by a technician with the proper diagnostic equipment and know how. j.
Jun 14, 2010 | Samsung Prostar 816 Phone
Sounds like the system defaulted programming.
Depending on the type of prostar 616 the only ringing station would be 1(or 21) with the porstar or 4(or 24) with the prostar plus.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
To program system speed dial numbersyou need the customer programming enabled (see the first part of programing ringing)
press the ALM/SD button
dial the 2 digit speed dialcode 10-98
dial the telephone number to be stored in that speed dial bank
press ALM/SD to store the number
Jun 01, 2010 | Samsung Prostar 816 Phone
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Jun 15, 2009 | Avaya Lands Phones
Phone dont ring
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished. hope that helps
Sep 04, 2008 | Samsung Prostar 824 Keyset Telephone
Samsung Prostar 816
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
Aug 30, 2008 | Samsung Prostar 816 Phone
Inactive Feature
The system lost programming. Call a vendor in...
May 07, 2008 | NorStar M7310 Corded Phone
Office phone, IBM-412CID, had power failure, reset phones, now cannot remove DND without constant ring
Must reset all extensions with individual extension numbers after a power outage. Just the same as starting the phone out of the box. Thanx.
Apr 28, 2008 | TT Systems Lands Phones
Only 1 phone rings
There is a small battery inside your main control unit that keeps programming in memory during a power outage. The life of the battery is about 5 years give or take. When the system goes down for an extended period (or possibly several quick on/off cycles) your programming will be wiped out. By default, only a few telephones will ring. The battery is most likely a small blue 3-cell battery soldered right on the main board. It's not easily replaced. You can get a technician to replace it or hook up a standard battery backup unit (UPS) made for a computer. Your phone system uses less power than a computer so it can use any UPS and will last longer than advertised. Hard to say exactly how long. Just don't re-program the system until you take care of the problem or it will just default on you again.
May 30, 2006 | Vodavi Starplus DHS 7312 Enhanced Phone
NEC DTU 8-1 Corded Phone Logo
260 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
