Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Grand WEGA continuously displays SATELLITE in upper left
Previously I could select DVD or SATELLITE. The selection would be briefly displayed in the upper left corner of the TV and then disappear once a show was running.
Now if I'm showing a satellite show, SATELLITE appears over the show until I switch to the DVD player. At that point DVD appears over the show until I switch to satellite. I want to eliminate the continuous displays.
Thanks.
  • 10,594 Answers
Please press " i " button on TV remote so on-screen display will disappear.
Posted on Mar 10, 2009
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
Coil not reset odo after oil change please let me know how I can reset
1 Turn key in electronic ignition switch control
unit to position " 1"
2 Press the system select button (S110s3)
repeatedly until the basic display (kilometer
reading display or temperature display) is
shown in the multifunction display (A1p13)
3 Briefly press trip odometer reset button (A1s3) 3
i A signal tone sounds and the voltage
times. display appears in the multifunction display
(A1p13).
4 Press lower scroll forward/back button (S110s1)
i The "Service menu" appears in the
multifunction display (A1p13).
5 Press buttons + and
-, setting of specific
functions and volume control (S111s1)
repeatedly and select "Confirmation" menu item
6 Press lower system selection button (S110s3)
i "Confirmation" appears in the multifunction
to confirm. display (A1p13) and the menu item "Complete
service" is shown against a sight bar in the
background
7 Press lower system selection button (S110s3)
i "Service confirmed" appears in the
to confirm. multifunction display (A1p13).
8 Press the upper system selection button
(S110s3) repeatedly until the "Service menu" is
9 Using the + and
-buttons, setting of specific
functions and volume control (S111s1) select
the menu item "Special work"
10 Press lower system selection button (S110s3)
to confirm.
11 Using the + and
functions and volume control (S111s1), select
menu item "Service 3"
12 Press lower system selection button (S110s3)
to confirm.
13 Select the button + and
-, setting of specific i "Standard oil" or "Oil quality 229.5".
the specification of the engine oil used
i
If only one oil quality is approved for the
engine, no oil selection is possible.
14 Press lower system selection button (S110s3)
i The message "Item confirmed" appears in
to confirm. the multifunction display (A1p13).
Copyright DaimlerChrysler AG 10/10/06 G/09/06. This WIS printout will not be recorded by the update service. Page 1
15 Press the upper system selection button
(S110s3) repeatedly until the basic display
(kilometer reading display or temperature
display) is shown in the multifunction display
(A1p13)
16 Turn key in electronic ignition switch control
unit to position " 0"
Copyright
Jun 22, 2012 | 2006 Mercedes-Benz R-Class
The Video selection display in the upper left corner will not turn off. I cannot find the original remote is there any other way to turn it off?
You need a SONY tv remote comander to de-select this function. You can use any remote from SONY TV or LCD with "on screen info" button.
Aug 30, 2011 | Sony FD Trinitron WEGA KV-36FS210 36" TV
My tv screen is zoomed in how to zoom out
  1. Check the TV to see if it has a ZOOM / WIDE option or control for adjusting the aspect ratio; if so, try setting it toNORMAL .
  2. NOTES:
    • If there is a SCREEN MODE button on the TV remote control, you can press this button until NORMAL is selected.
  3. If using a cable/satellite set-top box, DVD player or digital video recorder, check the device for aspect ratio controls and try selecting a different display option.
Jan 16, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony wega KF-50WE620 - cant get the screen into wide mode no matter what I do. HELP!!!
hi,
press the WIDE button on ur tvs remote for select the view mode. also check one more thing if ur connected a dvd player ,then go to its settings and select the video format as 16:9. do the same for the satellite receiver if it is there.
ok
Dec 31, 2010 | Sony Grand WEGA KF50WE620 Television
Video 5 / DTV disply in upper left screen will not go off.
Press Info / Display button on TV remote, on-screen display will disappear.
Sony TV Remote is required for that function, other remote wont work.
Thanks.
May 21, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
It wont display satellite(dish) or
If the satellite picture displays on other tvs in the house, and you have the satellite hooked up to the rear projection tv you may have to do the following:
1. Using the remote, select the input button. You will now see a menu of several choices.
2.Methodically go from one to the next until your satellite pix appears.
Nov 14, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Acer Travelmate2350 display flikkering
Seem that your screen resolution changed. Turn off the notebook and again switch it back press F8 until it shows a list of option and then select SAFE MODE. Select it and enter into safe mode.
After welcome screen Right click on Desktop and select properties.
You will get Display Properties window.
Then select the Settings TAB in Display Properties. There select the screen resolution as low as you can 640by480 or 800by 600 then select apply and restart the Laptop.
The notebool should work normally as previously it work.
Hope this will be usefull
Thanks & regards
Nanda Kishore.
Jun 09, 2009 | Acer TravelMate 2303WLCi Notebook
Changing the time
Here's a link to the manual Pioneer's web site.
Here's how you set the time (from page 16 in the manual):
1: press SOURCE and hold until the unit turns off.
2: Press AUDIO repeatedly until the clock appears in the display
3: Press (left arrow) or (right arrow) to select the segment of the clock display you wish to set (hours, minutes)
4: Press (up arrow) or (down arrow) to set the clock.
- To cancel clock settings, press BAND
- to save clock settings press AUDIO until the display stops blinking
Dec 25, 2007 | Pioneer DEH-1500 CD Player
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
46 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
