Question about Toshiba E-Studio 3511 Color Copier
Call for service
Total count 22880
  • Church_Boy21 May 20, 2009
    Everytime i try to print a few pages in color the copier stop at the 2 page and the call for service message pops-up. what do i do?
  • Andrew Houle May 11, 2010
    There should be a letter followed by a 3 digit code in the upper right corner of the display when it is saying call for service. Must have that to help you.
    Andrew
    Problem Solver:
  • 10 Answers
Hold down "C" key it should show you the error code
Posted on May 19, 2009
Hp Laserjet P2055d-Page Counts error
are you looking at the pages printed on the toner cart. print out the supplies page.
Jul 28, 2017 | HP Office Equipment & Supplies
The ribbon will only print red ink
While in the D position or PD position, N Count
is OFF. In the N Count N position every
Plus, Minus, Equals Plus, Equals Minus,
Memory Plus or Memory Minus key depression
is counted. The Accumulator and its N Count
or the GT N Count can be printed by
depression of the Subtotal or Total key. When
either Memory Subtotal or Memory Total is
depressed, Memory N Count will print. N Count
is always printed in red, left justified. If the
Equals key is depressed immediately after the
Subtotal Total, Memory Subtotal, or Memory
Total the average of the entries is printed.
When the N Count prints on the 7150, an audit
symbol will print to the left of the N Count.
The audit NA will identify the Accumulator
register N Count, NG will identify the GT
register N Count and NM will identify the
Memory N Count.
Apr 23, 2012 | Monroe 7130 Calculator
How do you clear count on a 9080c?
Depressing the red STOP button for approximately 5 seconds should clear the counter displayed on the control panel. The Total scan count for the machine (located under "Control-Panel, Scanners & Cameras, Canon 9080, right click & select properties) can only be reset via the service diagnostic utility.
Apr 21, 2012 | Canon DR-9080C Path-Through Scanner
How do I get the copier count on the Panasonic 150A?
Press auto/photo key, paper tray key, and one key sequentially to get into F mode. Press 7 and you will see F7. press start or okay the total count is under C02. Press auto/photo and clear/stop key to exit service mode. Hope this helps
Jul 18, 2011 | Panasonic DP-150A Copier
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scann
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
Put harness belt back on baby car seat
22880-mtta is an Eddie Bauer carseat. Go to http://www.eddiebauer.djgusa.com/usa/eng/Instructions
Enter the model number 22880-MTTA, and date of manufacture.
Nov 11, 2008 | Baby Gear
Page count
If you don't have the paper manual, check out the manual on Konica-Minolta's website: DI151 User Manual
From page 4-2 and following of the paper manual or page 48 and following of the PDF document: When 12,345 shows on the Total Count display: <the readout shows:> ct 01 23 45
When 1,234 shows on the PM count display: <the readout shows:> CP 00 12 34
To select a Total Check function: Press and hold the Clear/Stop key for three seconds. The total count will be displayed. Press and hold the Clear/Stop key again for three seconds to display the PM count. Press the Clear/Stop key to return to the previous status mode.
From the way it's written in the manual (I've never seen this machine), it sounds like the readout will pop up
ct
01
23
45
ct
... etc., so you may need to have something to take notes on.
Sep 18, 2008 | Minolta Di151 All-In-One Laser Printer
Add number of checks
on the 5660... on the printer tape there is "off" "on" IC (for item count) and GT (which might be grand total)
for every entry of $check you add the item count will total to the left of the register tape.
May 20, 2008 | Texas Instruments TI-5660 Calculator
Toshiba E-Studio 3511 Color Copier Logo
206 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
