Question about Palm Tungsten E2 (Multilingual) Handheld
SmartHeap error Memory error when syncing with Palm Desktop
5 Suggested Answers
SOURCE:
Bubbabear64
  • 2794 Answers
SOURCE: Can I sync an Ipod touch with my Palm Desktop for windows?
I don't believe that the Palm desktop manager is compatible with Ipod. Unless you have your contacts associated with Microsoft Outlook, that should work.
Posted on Dec 27, 2008
  • 62 Answers
SOURCE: Error in Palm Desktop on PC
You need version Palm desktop v6.2 (not v4) to run under Vista. If you have the 64 bit version of Vista you will have to use Bluetooth to transfer data, not USB. Enjoy and please rate this post.
Posted on Mar 23, 2009
  • 51 Answers
SOURCE: Syncing Palm Centro to Palm Software
Export your contacts out of Palm as a CV file then import them back into LotusNotes
Posted on Aug 06, 2009
  • 20 Answers
SOURCE: Treo 7550 - Recovery from crash without Palm Desktop Sync
no u must always hotsync every weekend, he will loose his data completly!!
srry
Posted on Sep 30, 2009
HI, I just bought a palm m105, refurbished, through Ebay. I've had problems with it spontaneously erasing it's memory, so I want to back it up on my computer. I got a sync base with it and am able to plug...
I found the desktop program for this at free downloads,its called Desktop Manager and it will add a hot sync for you. Make sure you chose the right model. Good luck.
Feb 06, 2010 | Palm m105 Handheld
Suddenly when I try to sync the Treo with the MAc(OS10.6.2) I get the following message: The application "HotSync Manager" could not be launched because of a shared library error: "" I had been...
You will most likely have to reinstall Palm Desktop because either a Shared Library is always in use or it's missing. A reinstall should help.
Feb 05, 2010 | Palm Treo 755p Smartphone
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Dec 22, 2009 | AT&T Palm Centro Cell Phone - White
Can's install SW on Treo 755p error "unable to locate users.dat"
users.dat is created in your named profile directory on the drive in the Palm folder. If it is missing, your computer can't sync properly to the device. Do a backup of your device using the palm desktop, this should recreate the file in your profile folder on the machine.
Oct 02, 2009 | Palm Treo 755p Smartphone
When I sync my palm with my desktop, it says that it has synced with errors. Why?
Can you be more specific?? maybe the error begin in the way you sync (overwrite palm information, overwrite the desktop information, confirm overwrite).
Regards,
Oct 15, 2008 | Computers & Internet
Palm T/X won't hot sync on Window XP Media Center Edition
i had that problem too. sorry it is bugging you.
i know you probably want to sync your data rught now. So for now try to disable the syncing of documents to go (just for now)
on palm desktop, look for the conduits and temporarily disable the syncing of docs to go. Also ensure you plug in your pda charger as well as the usb cable (I found out this helps through experience) and sync. (Just to back it up)
as for the documents to go, there is probably a file(document) that is generating the errors. please look through documents to go on your palm desktop and remove any file you feel is not necessary. also take note that it is best if your pda has some free memory on it. you may want to save those documents on a disk (If you are not already that is..) clearing up ram made my tx more stable esp during hot sync.
please let me know it that worked for you. i still have some suggestions
good luck and enjoy
Nov 05, 2007 | Palm TX Handheld
Why will my Garmin not sync into my computer?
First, right click the hotsync button in the task bar and make sure "USB" is selected (assuming you're using USB...).
If that doesn't work, let me know.
Oct 06, 2007 | Garmin iQue 3600 GPS Receiver
Palm data and ActiveSync
You won't be able to do that. Lotus Organizer as well as Lotus Notes and OutHook are PIM some plus e-mail, just like Palm Desktop is a PIM. So you can have the Treo sync with Lotus Organizer AND have the Axim sync with it also it is because there are conduits buit for them. There is a middleware that allows both to talk to one. Now if you can find a piece of software out there that will sync a PocketPC with Palm Desktop, I'm sure a lot of Palm converts would love to know that.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Cannot hoysync with outlook 2003
After installing, reinstalling, deleting, hard resets, hitting head against wall... I tried installing the Pocket Mirror conduit as a last ditch effort. An error message popped up saying it could not find the mapi32.dll file. I looked at another PC, located that file in the windows32 directory, copied it to my PC, and I was able to hotsync with Outlook. To test this, I uninstalled the Pocket Mirror and Palm desktop SW, then deleted the mapi32.dll. Installed the Palm 4.1.4 sw, outlook 101 update, plus the conduit update, had same error messages. Added the mapi32.dll to the windows32 directory - was able to successfully sync with Outlook!
Sep 11, 2005 | Palm Tungsten E Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Palm Tungsten E2 (Multilingual) Handheld Logo
60 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
