Question about Kenmore 23822 Top Load Washer
Will not spin on spin cycle
Will not turn or spin on any cycle. Sounds as if it wants to turn but seems to be stuck.
  • 163 Answers
The drive coupler is bad.you can find it between the motor and transmission.
Posted on Mar 10, 2009
The time remaining on the readout seemed to be stuck at 8minutes left in the spin cycle is this normal..?..
This sounds like your machine could not be draining, if the washer cannot drain the water it will not spin. Eight minutes sounds about right for the final spin. If your machine has a pump clean out check to see if there is anything in it plugging the drain pump.
Dec 03, 2017 | Washing Machines
Whirlpool Washer not drain, with clicking noise
If it has a filter, clean it out and start again
Mar 15, 2017 | Whirlpool LSR7333 Top Load Washer
In final spin cycle my washer sounds like a jet engine ready to
the lenth of duration in all cicles are controled by the timer that is the part that you turn clock wise. also need to check the belt adjustment. If is direct drive, then check the motor mount and berings
Aug 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washing machine is locked up and will not spin.
Sounds Like The Belt If Inclined Remove The Outer Case Front And Replace Belt Of Equal Size From Any Auto Parts Store.
Jan 05, 2009 | Granberg Bar Mount Chain Saw Sharpener,...
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Washer does not engage in spin cycle
could be a stuck gear box. this gear box could have a mechanical problem on the spin cycle.
it usually turns the reverse rotation if it wants to spin.
check the pulley of the gear box, rotate it in one direction for twenty revolutions. see if it agitates. then next turn it on the other direction and observe if it is binding or stuck.
if you can remove the gear box and check the mechanical gears inside, maybe you can find the problem and replace the part.
tnx 4 using fixya,
drcool
Oct 16, 2008 | Frigidaire CWS3600AS Top Load Washer
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 23822 Top Load Washer Logo
Sal De
fordexpert
 Brian Main
Brian Main
