Question about Sony Ericsson w580i Cellular Phone
My cell phone is just blinking a red light on the right hand side and does not want to switch on.
When mine does that, It means that the battery is dead.
You should plug it in to charge.
Posted on Mar 10, 2009
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
I have a Uniden Dect6.0. The message light in the upper left-hand corner of the phone continues to blink, but when I push the message button on the lower right-hand side of the phone, the recording says I...
You have unheard messages on the voicemail system provided by your telephone company. This system takes messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 19, 2011 | Uniden DECT 6.0 Cordless Phone ID
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F65 Mini Not used.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F76 Mini Not used.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
Jan 07, 2011 | 2003 Jaguar X-Type
When i switch on my mobile a red light is blinking on the top... what it mean?
dude u gotta charge ur cell well...
the red light blinks wen u r low or can say out of power..
Sep 26, 2009 | Sony Ericsson W700i Cellular Phone
K610i phone blinking red light 5 times after i replace another sim
If it blinks red light 5 times, it means the battery is completely empty and you have to charge the phone...The charge is completely dry.Try charging for some time, and try switching the phone ON
RNJ VINOD KUMAR
Sep 20, 2009 | Ericsson Cell Phones
Sony ericsson w580i wont turn on light on side blinks red
Please visit the Sony Ericson technical shop, donot try to open because once the seal breaks, warranty gets over
Jun 16, 2009 | Sony Ericsson W890i Cellular Phone
Hi...I have a w580i phone which is six months old....I put the charger in my phone & a red light flashed & now my phone will not charge or switch on....I hold the power button & get one red...
Hi
Please contact a skilled mechanic nereby and request him to 'boost up' the VOLTAGE of your handset's battery which should be minimum 3.2.
Thanks.
Supriyo DG
Jun 20, 2008 | Cell Phones
Little red light ,
Try taking out the battery for a few hours. The red light should turn off.
May 27, 2008 | Sony Ericsson K800i Cellular Phone
Uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Feb 07, 2008 | Uniden Cordless Phone
Sony Ericsson w580i Cellular Phone Logo
89 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
