Question about Health & Beauty
Voltage: own a 220 volt Series 3 330 shaver , now in Canada 110 v
Is there an adapter available to allow me to charge my 220 volt Braun Series 3 330 razor now that I live in Canada where the electricity is 100/115 volts?
  • Anonymous Mar 31, 2014
    was shaving turned razor off to put more soap on and razor would not restart. It was fully charges. Any suggestions as to what to check?
  • 31 Answers
You can try dryer power port, it's 220V, and you have to buy a adapter to replace the port on the wall accord with your Braun, or to buy a transformer (110 - 220).
Posted on Mar 10, 2009
I have bought a Braun epilator 7 , Braun type:5377 , in USA and have purchased the charger in the UK which is 100-240 v , do I still need to get a voltage converter to be able to use it in the UK ?
If the charger is 100 to 240VAC, it should work. USA use 110 volt so the charger should be OK with 240. The UK charger will probably have a UK 3 pin plug on it. If you use it in the US, you will have to change the plug again or buy an international adaptor which can be adapted to fit most outlets anywhere in the World.
Apr 19, 2015 | Braun Health & Beauty
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
Charger arm will not stay locked in place to charge the razor
This is a common problem for older cleaning bases. The part is worn out. You will need to replace the upper housing of the cleaning base. You will find this item available at shaveroutlet.com. See link below
If repairing the unit is not your thing, you can replace the entire unit instead. See item linked below
Jul 08, 2011 | Braun Syncro 7526 Electric Shaver
I cannot click the top on when i try to charge it ....
The latch on the 'arm' of the clean and charging base is broken. You can either change out the top portion of the clean/charge base or replace the whole thing if you don't thisnk you can do the repair.
Both itemsare available at shaveroutlet.com. See links below. Basic instructions for installing the top part are included on the item page
Sep 26, 2010 | Braun Syncro 7570 Electric Shaver
Will it be okay to connect a 110 volt laptop to a 220 volt LCD projector?
What voltage is your mains supply?
The laptop's adapter should be a multi-voltage type 110 to 240 volts input.
If your mains is 110 volts AC then the 220 volt AC LCD projector won't work unless you connect it to a step up transformer (110 to 220 volt transformer).
If your mains supply is 220 or 240 volts then both the laptop and the LCD projector will work without any problems.
Aug 24, 2010 | Computers & Internet
Hi there, A friend gave me this shaver but there is no charging cord or adapter. I can probably make my own but I need to know if this shave plugs directly into 110-115 AC or whether there is an adapter...
<P>The 8985 shaver only takes about 7&nbsp;volts.&nbsp; The charger that you are missing can be used with 100-240V and has a transformer in&nbsp;the plug&nbsp;that reduces the voltage to just a few volts to charge the shaver.&nbsp; If you connect 100-120V directly into the shaver, you will ruin the shaver.&nbsp; I strongly suggest that you buy the correct cord.&nbsp; You will find it available at shaveroutlet.com.&nbsp; See link below</P><P>&nbsp;</P><P><A href="http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html">http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html</A></P>
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
My former razor, Braun 5414 would take 110-240AC as well as 12 DC. Now have Contour 5790, and want to know if itcan also use12 volt DC.
According to the Braun manual for your 5414 Contour, the specs for charging are printed on the electric shaver cord plug. (it's REALLY small print, so I'd get a magnifying lens to look at it!)
There isn't anything in the manual about the multiple voltage for charging the shaver, so I'd have to defer to the Braun (Gillette/Proctor & Gamble) customer service folks to make absolutely certain of what can and can't be used as a charging voltage before trying.
Here's a link to your manual, in case you're missing yours.
http://www.retrevo.com/d/ds/progress?doc=9142c4ae65df1746d12fc67fdc01df52
You can ALSO reach the Braun Customer Service folks by calling them at 1-800-BRAUN 11 (1-800-272-8611)
I hope you find this Very Helpful and best regards!
Oct 06, 2009 | Braun Health & Beauty
I will go in Italy , may I use 220 V to charge my Philishave 5825 ?
If your shaver is a 110/120 V-AC razor, you MUST use a voltage converter that will allow you to charge/use your shaver while on your trip.
I would not reccommend you attempt to use it directly, since you still would need a special cord with a plug for the different outlets in Europe.
Purchase a converter/adapter kit and you can use anything with your existing power cords, with the proper adapters in the kit, without an worries.
Have a great trip and hope you find this Very Helpful. Best regards!
Sep 07, 2009 | Philips Health & Beauty
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Health & Beauty Logo
348 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
