Question about SGI Silicon Graphics Silicon Graphics 320 PC Desktop
My silicon graphics 02 computer power switch is stuck in the on position. When i pull the plug and plug it back in it gets power. The amber light burns steady. The reset button is showing power but has no effect. The hard drive is running but the computer will not boot. It cannot be turned off with the power switch.
    Genius:
  • 1,061 Answers
POWER SWITCH WENT BAD ORDER A NEW ONE AND RELPCE OR HAVE A LOCAL SHOP DO IT.RICHARDM69
Posted on Mar 10, 2009
Wipers keep running wont shut off
Electrical control to the wiper motor are also stuck in "on". It could be the switch, or the relay for power to the wiper motor or a short somewhere to a positive source of power. You should be able to remove the wire connection to the wiper motor, but protect it from shorting on any body metal (ground) or negative. by with tape on the end. Until you get the problem sorted out.
Mar 22, 2015 | Cars & Trucks
Whirlpool sideby side refrig, water dispensor won't stop flowing aready replaced water control valves
You said you replaced the water control valve which I assume is the valve on the refrigerator back. If it is still running water all the time with the refrigerator plugged in, pull the plug and see if it stops. If it does, you have a switch in the dispenser area stuck closed in the water on position. If you pull the plug and the water still continues to flow, the new valve is defective and stuck in the open position.
Mar 07, 2015 | Whirlpool Refrigerators
Paper shredder doesn't move due to too much adhesive paper - how to fix it
Before trying anything I suggest, make sure your shredder isn't plugged in.
You will need to remove the adhesive from the rollers. You will need to use a glue solvent on the shredder rollers,something like Goo Be Gone. Personally, I still use Ronsonol Lighter Fluid In the image below I've outlined the supplies you'll need to, hopefully, clear your jam.
25346531-f3timxio4jyou4u0bydnlgfi-2-0.jpg Without disassembling your shredder, the best way to clear your jam is to use Rosonol Lighter Fluid (3), tweezers (4), and dental picks (5).
  1. Make sure you are working in a well ventilated area. Separate the shredder from its shredded paper collection tub.
  2. Turn the shredder head upside down so that the paper output is facing up.
  3. Pour Rosonol lighter fluid on both sides of the rollers near where they come together.
  4. Use dental picks and tweezers to dislodge stuck paper pieces
  5. Turn Shredder head over and repeat steps 3 and 4
  6. Move power switch to the "Off" position
  7. Plug power cable back in
  8. Move power switch to "Rev" (reverse) position, if still stuck move power switch to the "Fwd" position, repeat twice
  9. Repeat steps 1 - 8 until the rollers move freely
Once the rollers are moving smoothly you need to oil the rollers.
Dec 30, 2014 | Shredder Office Equipment & Supplies
It wont turn on the button seems to be stuck in a unpushable position
You need to open it up and remove the switch PCB assembly from the front panel, then you will see the plastic power push button that is attached to the front panel by a couple plastic stems that were melted on to hold the button in place (cheapy way of making the monitor), you can try using the siliocne adhesive to hold the button in place since the silicone is flexible (that is what I use for fixing broken button/hinges)
Mar 05, 2010 | Dell E173FP 17" LCD Monitor
Is there a generic power cable for this monito?
We have a generic AC adapter that will work on the SGI F180 monitor. Go to our web site at:
www.ccl-la.com and click on LCD power link. The correct one is the high current adapter, the F180 draws 5.8 amps at 12volts.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | SGI Silicon Graphics Silicon Graphics F180...
NO HEAT ON FLOOR, I INSTALLED A NEW ACTUATOR BUT STILL NO AIR ON FLOOR SETTING , I HAVE THE SAME PROBLEM WITH MY 99 S-10. IS THERE A PROBLEM IN THE SWITCH WHICH CONTROLS THE DIFFERENT AREAS IN WHICH YOU...
The floor usally has a vaccum servo,so check it to see if the servo is moving.Pull the ac/heater control from dash,and remove the vaccum plug.Spray some silicone(silicone spray only)in the vaccum lines(plug)and the receptical for the plug.Do this while it is on,and engine running,this will unstick the vaccum switch if it is stuck.Also before starting this,check for vaccum at this vaccum switch.If there is no vaccum,go under hood and follow the vaccum comming out of firewall,and find a vaccum reservoir,or a vaccum check valve,and check them to see if they are damaged or not connected.I hope this helps,if you need more help let me know.
Oct 05, 2009 | 2002 Chevrolet TrailBlazer
The Acer X1700 desktop suddenly stopped booting.
i would check your power supply. take it to a local computer shop. or call acer for warranty support.
or if you are running on a backup ups, plug the computer directly into the wall and try it again
Sep 23, 2009 | Acer Aspire™ T180 PC Desktop
SGI F180 Flat Panel Display no longer turns on.
If the power button does not stay on, the monitor might be burned out.
Aug 20, 2009 | SGI Silicon Graphics Silicon Graphics F180...
Dodge caravan 1997 3.3l Xavierfrancofuenmayor
Had similar problems occur on various Chrysler products manufactured since 1986. What I did was remove the computer from the car and then take a Dremel tool with wire brush attachment and lightly buff all the pins of the computer--tops, sides and backs. After this I then take a jewelers round file and insert the tip into each connector pin hole and very lightly file it to remove any corrision. When I reassembling the connector plug to the computer I placed a good size dab of silicon grease on the plug in the center (acts as a seal when seated). This has eliminated the problem on four different vehicles.
Jun 11, 2008 | 1997 Dodge Caravan
SGI Silicon Graphics Silicon Graphics 320 PC Desktop Logo
96 people viewed this question
Top SGI Silicon Graphics Computers & Internet Experts
David Payne
David Payne
Are you a SGI Silicon Graphics Computer and Internet Expert? Answer questions, earn points and help others
