Question about Canon IXUS 80 IS Digital Camera
Pic are not copy computer to camera? - Canon IXUS 80 IS Digital Camera
  • 68 Answers
If you are not able to transfer data from comp to card. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... But some pics have higher resolution than your cam,so pics may not be visible on cam's LCD OR it may show pics are not compatible Hope this helps you out.. :)
Posted on Mar 10, 2009
My camera will not upload pics, it says that there is no pics/videos to upload at this time! Even though I have 84 pics there!
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 24, 2012 | Kodak EasyShare C143 Digital Camera
I have a pentax optio s10,lost ma ual but can,t figure out how to transfer pics from camera memory to sd card in camera, HELP!!!
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
You may view the manual at
Pentax Optio Optio S10 Operating Manual
"Copying files" begins on page 164.
Nov 20, 2011 | Pentax Optio S10 Digital Camera
Sony cyber shot 7.2 Carl Zeiss transfer pics on memory card
No.
Take the memory stick out of the camera then connect to the computer. You can then transfer the pictures from the camera to the computer.
Alternatively, use the camera's copy command to copy the pictures from the internal memory to the memory stick.
Jul 12, 2009 | Cameras
Pentax Optio Z10
Haven’t been able to find any software, but you can try the following workaround:
1. Plug in the camera to the PC and ensure it is detected by the PC.
2. Right click START button and select Explore.
3. From the left panel, scroll to the drive corresponding to your camera. (It will usually be located after the last DVD/CD ROM Drive letter.
4. Click on that drive to expand the folders in the right pane.
5. Search for the relevant pictures from a folder within that drive.
6. Copy the required pics (Hold CTRL and click on pics in case you want to select more than one pic). Then rightt click and select "COPY"
7. Once you copied all the needed pics, select a folder on your computer (or create a new one) and paste the pics into this folder.
8. You're done :)
An external memory card reader is an easy alternative way to copy files from your
camera's memory card to your computer.
Hope that helps! Should you have any further questions, please feel free to post them here.
Jun 23, 2009 | Cameras
I need drivers for irocks ir3230. could you help me?
8. You're done :)
An external memory card reader is an easy alternative way to copy files from your camera's memory card to your computer.
Jun 19, 2009 | Cameras
Cannot load pics to computer..It says "No media files loaded".BUT the pics are still on my camera.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak easyshare z740 how to copy pics from internal memory to an
if you have the cord that came with the camera and the easy shareware , load the software in the computer , plug the camera into the cord and then into the usb port in your computer then press share on the camera and you should see the pics you took and then download them.
Dec 26, 2008 | Kodak EasyShare Z740 Digital Camera
Copying files to the computer
  It would be easier to diagnose the problem if you'd upload a picture.    Have you had similar problems with cameras that don't use batteries? And if so, how do you go about resetting them once they are unplugged? Proper resetting is critical!   Some older cameras (usually those with no batteries) have a selector somewhere near the PC cord socket, labeled "M" in the one position or "X" in the other. These stand for "Microsoft" and "OSX". Having it set to the wrong position for your PC can cause upload failures. Newer cameras work with either automatically.
Apr 06, 2008 | Photography
Sep 29, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Cant see folder on computer
There are few method to copy the pic from camera to pc. 1) disable yr anti virus b4 connect the camera to pc. 2) re-install the camera driver on pc again 3) use card reader to transfer the pic to pc. Hope it help
Sep 05, 2007 | Fuji FinePix A345 Digital Camera
Canon IXUS 80 IS Digital Camera Logo
119 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
