Question about GE JBP22BK Electric Kitchen Range
Wire connection for bake element
Ge range jbp22ges1wh. I have two black wires and one yellow. Some one took the old element out, so I have no idea how to reconnect it.
4 Suggested Answers
  • 969 Answers
SOURCE: Need to replace bake element in GE oven model
LOOK FOR SCREW ATTACHING ELEMENT TO BACK OF OVEN INSIDE OVEN, REMOVE SCREWS, SLIP OFF WIRES. MAKE SURE POWER OFF!!!
Posted on Nov 12, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have a GE range
Hello, welcome to Fixya.
I understand you are replacing your bake element and are uncertain of wire placement, correct ? My first suggestion would be to locate the tech sheet/wiring diagram, or tracing the yellow wire. I suspect the 2 black are "hot" and the yellow (maybe with a green tracer on it?) is ground/earth...though I don't have a diagram either. Let me know what you find and I'll try to help you going forward. Good luck and thanks for choosing FixYa today.
Regards,
Macmarkus :)
Posted on Jul 10, 2011
  • 5370 Answers
SOURCE: I replaced a dual burner
Whats the exact brand of the ge electric range and what are the colors of wire.Are there 3 wires going to element or 5 wires.In most ranges there goes 3 wires.But still give exact brand and wire color code.Are the wires coming from element or wires going to elements.-------- Keep updated, with the details.Thanks.Helpmech.
Posted on Jul 31, 2011
Have a lg oven lre30453st that the oven doent work the displa shows F7 clear the clock and unpluged it for 5min and still doesnt work.push the bake button it showed 375 thena second later went to...
Be sure you have 230 volts across the red and black wires at the terminal block the power cord attaches to. I suspect you have only one line to the range.
It is simpler to check a portion of the range first. Go to the relay board for the bake and broil elements. Check for incoming voltage between the red and black wires. You should have 230 volts all the time.
Set the oven control to bake at 350 degrees and check between the yellow and black wires that go to the bake element. You should have 230 volts. If you have 0 volts, check between the yellow wire that goes to the bake element and the black wire that goes to the terminal block of the range. If you have 230 volts here, the DLB relay on the relay board is bad. This will prevent bake and broil from working.
We can go through the relay board for the cooktop. I think it is best to eliminate one problem at a time.
Oct 16, 2011 | LG LRE30453ST (Electric) Stainless Steel...
I have a GE range in which the baking element cracked in one place and needed replaced. I removed the old baking element and was getting ready to install the new one when I noticed that there were not 2...
Regards,
Macmarkus :)
Jul 09, 2011 | GE JBP65 Electric Kitchen Range
I am installing the bottom element in my ge range and there are 3 wires 2 black one yellow how do i know which one goes where
All green/yellow wires are earth and they connect to the bracket/frame of the element. If the element only has 2 spade terminals it doesn't matter which way the 2 blacks go, the element has no polarity.
Mar 04, 2011 | Kitchen Ranges
GE Oven # J BP65G V1AD. Wires burned through 2" behind attachment point to element. replaced wire with 14 awg stranded high heat nickel appliance wire. In process I erased the pencil mark...
normally theres 2 wires on the right side spade lug looking in from the oven front where it plugs in and both of the bake elements have a black wire on the spades and the right side has 2 wires off that terminal,but to simplify the correct connection take a volt-meter (NOT connecting the element) and connect to the single black wire on the left spade on the element on one meter probe and connect the right side to the other wires at a time and then switch on the oven and broiler at separate times and see which wires read 240volts when that switch is energized at that time
Dec 24, 2010 | Kitchen Ranges
Where to connect third (yellow) wire to lower heating element
A local appliance repairman solved the problem in ten minutes. Charged me $30.00. The two black wires fasten to one terminal, the yellow wire fastens to the other.
I notice you have billed me for your service. Your ads advice if the problem cannot be solved by your technicians, there is no charge. Please credit my account.
Nov 12, 2008 | GE JKS06BFBB Electric Single Oven
Oven lower element wiring
I just looked at the back wiring of my JBP90 oven. The main element (bottom) has both black wires together on one element terminal and the single yellow wire on the opposite terminal. Not that it should matter, but both blacks are on the left and the yellow is on the right as viewed from behind the oven.
Good Luck!
Jan 14, 2008 | GE JBP90 Electric Kitchen Range
Bake Element
There should only be two wires that go to the element. It won't matter which wire goes on which terminal. Turn power off to unit before replacing the element. In some cases when the element burns out and breaks in have it will send a surge back to the oven control board and it will need to be replaced also. You will know once the element is replaced if it doesn't heat up.
Oct 01, 2007 | GE JBP90 Electric Kitchen Range
GE JBP22BK Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
