Question about Hyundai L91A 19" LCD Monitor
Monitor adjustment panel keeps flashing on and off
Hyundai 22" flatscreen. Adjustment panel for monitor settings keeps flashing on and off. Tends to stay off in you stay mouse active, but after a very short wait period, it starts flashing again.
  • charles_simo Mar 10, 2009
    There is a set of buttons on the left lower edge of the monitor. I have tried using the menu button, even to the point of holding it down, and cannot get the menu that is flashing to either halt, or come up solid.
  • Is it the adjustment panel on the monitor, or is it a software adjustment that came with monitor?
There are 8 electrolytic capacitors on the power supply board which is the one that the power cord goes to. The best option is to replace all of them. These are of the type referred to as "low ESR" and they are rated at 105 degrees Celcius. The bad news is that you need to be reasonablly good at soldering if you want to replace them yourself. The good news is that the capacitors are not expensive, certainly much less expensive than a new monitor. Most of the values are critical since the space alloted on the circuit board is very limited, so tolerance in substitution is limited.
Posted on May 05, 2009
  • 25 Answers
From the sound of it, it looks like these buttons may be defective. Contact Your store where You bought it, and ask for a replacement, or repair.
Posted on Mar 10, 2009
New purchase. VGA connection. First use, all was fine. Turned off, then back on, and image will not "center." Neither VGA Automatic nor the individual controls will adjust the horizontal enough...
Make sure you have your resolution set to 1680 x 1050 as this is the native supported screen size for this LCD. Also check your graphic card's overscan or manual adjustment settings. They might be manually set to offset the screen picture.
Hope this helps,
Chris
Jun 29, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
How to adjust monitor screen brightness?
hi. turn on the tv and then use the remote. click on the menu and scan thru til you find picture brightness or picture quality. J.
Jul 29, 2010 | Acer X223WB 22" WIDESCREEN LCD Monitor
Problem is i cant adjust colour and size because of showing "LOCK
This is how:
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
User manual:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=2233BW&prd_ia_sub_class_cd=P
Apr 23, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Mar 29, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
No picture - only "Adjusting" message flashing/floating on screen
your LCD panel is fried!! those flat screens are notorious for that
Jan 14, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
My 19" flatscreen monitor flashes on a blank screen and the power button light flashes on and off blue, no picture.
Problem in Your monitor VGA cable no horizental or Vertical signal.So it is not active standby mode.Check signal or VGA cable on not adjust properly CPU.or any other device.May be VGA cable was broken.Replace it.If you are not replace the part so you can get help any service technician.
Dec 27, 2009 | Soyo 19" LCD Flat Panel Monitor
I keep getting a flashing "auto aujustment in progress recom setting 1440 x 900- 60hz it just keeps flashing but wont adjust
Go to menu on the bottom of your monitor. Select "image control" once there click auto adjustment. That should change it. Let me know.:)
Jun 25, 2009 | HP w1907 LCD Monitor
Tilting Problem with monitor
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Jun 06, 2009 | Acer 22" X223w LCD Monitor
Pl716s2 flatscreen
Hey...
Well, your lucks just run out....you got a busted backlight inverter.
Aug 22, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Hyundai L91A 19" LCD Monitor Logo
405 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
