Question about Polar A5 Wrist Watch
Polar a5 wrist strap replacement
How do I replace the wrist ******** a Polar a5? The pins are not spring loaded. Thanks...tony
  • 2334 Answers
SOURCE: can not change battery on Polar chest strap
Yes, there are a few.
1) As you may noticed, coin and even screwdriver blades are never sharp, but mostly blunt. So, sharpen the edge of the coin on a piece of sandpaper. Get hardened steel screwdriver or very sharp, pointed end file and scrape that indention (groove) to make sure the channel have straight sides, forming I_I shaped groove, but not V shaped groove. When done, insert the sharpened coin and unscrew the battery cover using some pressure as well.
2) In case if the groove is stripped completely, you will have to drill two small holes into the battery cover. Drill them 1mm from the battery cover's edge on opposite sides. Depth of holes should be 0.5 mm. Do not drill through completely. For drilling use 0.3-0.5 mm diameter drill bit.
When finished with both holes, take hardened tweezers, insert each arm into separate hole and unscrew the battery cover.
Do not forget to rate, please.
Posted on Jan 25, 2009
  • 2334 Answers
SOURCE: how do I change a battery on polar monitor F6
Open Caseback. Unclip the contact. Replace battery, clip contact back and put the caseback on.
Posted on Mar 23, 2009
SOURCE: How to change the battery on a Polar F11 Heart Monitor
Here are instructions (with images included) on how to replace the battery for a Polar F11:
Posted on Jun 19, 2009
  • 25 Answers
SOURCE: Polar CE0537
I have changed batterys in these watches but i can only describe the process from memory which may be faulty. You may or may not have to remove the strap depending on whether it covers any of the case back. Unscrew all screws on back and remove. I believe these watches have a triangular spring loaded plate over the battery which needs to be slid out to (bit tricky) note which way up battery is. Replace battery 2032 i think replace cover short AC or AR with +ve replace seal,back,screws etc. this is a link to manual for confirmation's-Manual-==TVRFM09URXg=.html
Posted on Aug 22, 2009
SOURCE: how to replace battery in polar f4 watch
Posted on Nov 28, 2009
How do i get a polar f7 watch band replaced the watch is just over 2 years old
You can get replacement band on amazon, click here and take a look Amazon com polar band replacement. I hope this was helpful, have a nice day
Feb 03, 2012 | Polar Electro POLAR FT40 Heartrate Monitor...
Took apart a polar s150 watch to change the battery. I went too far and 2 little springs fell out and a small black rubber donut. I don't know how/where to put these back. The two springs appear to...
Hello Clintsanders,
I am sorry to inform you but there is no way that you can repair the unit yourself, you will need to return the unit to Polar to be repaired. Here is a LINK to Polar and all of there service centers and the numbers and procedure that you need to follow in order to return your unit for repair.
Sorry but this is not a DIY item.
Thank you for choosing
May 16, 2011 | Polar S150 Heart Rate Monitor Wrist Watch
My wife asked me to set the time on her watch. She no longer has a manual. Can you help? It is a polar CE0537 Polar Electro and has two side buttons but no button in front. Thank you.
There is a link to download any Polar manual in PDF form in my tips and tricks page.
Are you sure there is no button in front? Polar watches are all activated for exercise recording by a front button. And if it is an A5 as the request and picture show there is definitely a front button.
On the back of the unit, near the upper portion of the backing will be the model number it will be a letter/ number code like A5, M32, etc... The CE0537 is a different coding than the model itself. You will need the model number for the correct manual.
Apr 25, 2011 | Polar A5 Wrist Watch
Reset button has no impact on S120 - no functions available other than time of day
The S120 is now a fairly old watch. When the function buttons and heart rate cease to function this is generally an indicator that the battery needs to be replaced. The buttons themselves can also become worn out or weak of function, in either case you have a couple of options.
1) send in to a Polar Authorized Service center: This is very important, do not take to a normal watch shop. You need the watch properly resealed and handled correctly as well as you may need parts such as a button return spring they will not have. Plus there is a 90day warranty on Polar's repair. You will also need to send in your chest strap just to make sure that is still functioning properly. Battery repair about $15-, new buttons another $10ish, and a chest strap if needs replacing about $25 or $30-. $50-$60 total if everything needs work, but this is just an estimate.
2) buy a new watch unit. The RS100 (the current replacement) is about $100- and is easier to use with a better chest strap.
Dec 28, 2010 | Polar S120 Wrist Watch
How can i get the manuel instruction for polar a5and how to set this heart montor watch?
For all those who lost their Polar Heart Rate Monitor manuals. Follow this link, fill in the details and get manual. Plenty of other Polar product info and support on this site.
Nov 21, 2010 | Polar A5 Wrist Watch
Is it worth trying to replace battery of my heart rate monitor
You certainly have had good service out of the battery. It is best left to a watch repairer to replace the battery.
Feb 10, 2010 | Polar F4 Heart Rate Monitor Watch
Wrist watch- at times the watch isn't showing
Manger de la marde vous êtes des crosseurs!
Vous mériteriez d'être poursuivis pour faire perdre tant de temps aux gens, pour vous approprier les solutions que les bonnes gens trouvent et ensuite faire de l'argent avec.
Oct 26, 2009 | Polar A5 Wrist Watch
Polar CE0537
you need CR2032 lithium batteries. They can be found on amazon (pretty cheap). here Finally charging for our multi device world
click on the link and chose some (by price or vendor...) I hope this was helpful. cheers
Aug 20, 2009 | Polar A5 Wrist Watch
Polar A5 wrist watch
Have you thought of taking it into a watch specialist.
I would advise you not to accept adresses on this site for your watch to get repaired .
Does it run on a lithium battery ?
Aug 04, 2008 | Polar A5 Wrist Watch
Polar A5 Wrist Watch Logo
211 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
