Question about Panasonic PT-52LCX65 44" HDTV
Red, green, blue spots rear projection tv
I have multi colored spots what do i do?
  • Wharton05 Apr 03, 2009
    i just replaced the bulb 10 min ago, have the same problem. and still says i need to replace the bulb. WTF!
  • spqr163
    spqr163 May 11, 2010
    when was the last time you changed the bulb? cause it sounds like you need a new one..
  • 3 Answers
Contact Panasonic to have this corrected. They will pay for it even if it is out of warranty. I contacted a local repair shop first and they wanted $255 to fix it in their shop. I called panasonic and they scheduled the same shop to come to my home and fix it in about 20 minutes. Way to go Panasonic.
Posted on Apr 10, 2009
It is a technical issue that only be solved by calling in a repair agent. The internal coing must be reset using an external disc which re-copies over good coding back itno the TV. If you still have warranty this will be covered....good luck
I have a 55 inch rear projection mitsubishi tv. it recently has started showing what looks to be white spots when viewed at a distance on a dark screen. when you look at it closely it actually is red green...
It is called Convergence. You have three CRTs. Red, blue, Green. When they are not aligned, you will see the individual colors. See if you can do some alignment in the users menu. Look for Converge or Convergence in the menu. Either under video or setup.
Mar 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Guns on their last leg- color fading
If you are asking about Guns in rear projection tv then answer is No.
Rear projection TV has 3 Guns (CRTs), red-green and blue and each gun has its unique color phosphorus coating to produce its mono color (red /green /blue) and these are not interchangeable.
Need further info, let me know.
Oct 23, 2008 | Televison & Video
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
Red Blue and Green?
All colors in a tv are made up of red ,blue and green,,. my projection in the menu has under setup,,just check for it,,its called conversion ,it realines the colors,, you have to do it periodicaly,or sooner if you move a projection tv,, thanks,, .it should have it,,good luck
Oct 05, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
259 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
