Question about Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point
Does the Apple Airport Express 802.11b/g have an instruction manual?
  • 2,460 Answers
Of course it does. Will this one do? http://public.carl.airpost.net/AirPortExpressSetupGuide.pdf
Carl
Posted on Mar 10, 2009
How to change the password on Apple airport express ?
Unplug the AirPort Express from the power outlet and press and hold the reset button. While still holding down the reset button, plug the device into a power outlet. Hold down the reset button until you see the light flash green four times. Let go of the button and the device will reset itself. Wait the requisite 45 seconds and configure it with the AirPort Express Assistant or AirPort Admin Utility.
This performs a factory reset.
May 05, 2011 | Apple AirPort Express Base Station with...
I am using the airport express to play itunes through my stereo only. I unplugged the unit to move it to a more convenient place and now I cannot to get it to work. It was working well before. I...
From my reading at the Apple support web site, it appears that you may need to download the latest version of the Airport Utility in order to get around this issue.
Additionally, Apple has just recently come up with an update to the firmware for this device.
Try downloading the latest version of the Airport Utility (Mac or Windows) and see if that doesn't resolve the issue.
After installing the latest version of the Airport Utility, try to connect to the Airport Express. If that is successful with the new version, click the "Manual Setup" button to display the "Summary" page for the Airport Express.
Next to the entry for "Version:" there should be a button to press to upgrade the firmware to the latest version (7.5.2). Perform the upgrade by following the on screen directions.
After the upgrade, again attempt to connect to the Airport Express using the Airport Utility. This should work as expected.
Before attempting to use the AirTunes (recently renamed "AirPlay"), make sure that you have the latest version of iTunes installed.
Dec 27, 2010 | Apple AirPort Express Base Station with...
Only one computer on my wireless network finds Airport Express. I have Airport utility installed on both of my laptops in my network, but only one of them finds the Airport Express? I can ping the...
Dial 1-800-204-4427 US Toll-free Number & Get the best assistance for Trusted Apple Technical support. We proffer an online Apple Technical Support assistance to the customers and fix their glitches in a professional manner. Read More... Apple Customer Support Number 1 800 204 4427
Jun 19, 2017 | Apple AirPort Express Base Station with...
Airport utility cannot find airport express - ask for rescan
connect a ethernet cable to it. find it in the utility and reset it.
Jun 07, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Not able to connect to internet via airport express
Have you checked your system preferences, network settings? You have to tell the mac to use airport or ethernet. It may be setup to use the hard wire and not airport. You should see a link to turn on airport in the upper right corner of your screen. I think you can turn airport on there.
Apr 03, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Using to Print Wirelessly
mac or windows? Here's the airport express firmware update which resolves a lot of known issue regarding the express.
windows:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63forwindows.html
mac:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63formacosx.html
May 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point Logo
141 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
