Question about GE Spectra JBP78 Electric Kitchen Range
Replacing oven element
Oven element went out on GE range. I unscrewed it from oven wall. I don't see screws to detach the two wires. How do I detach them?
  • 15 Answers
When the element is removed from the rear cavity wall, the wires should pull off the spade ends of the element using something like pliers.
Posted on Mar 10, 2009
Replacing element in oven
Pull out the oven & unplug it. If element is screwed to the back wall of the inside of oven, you can remove the screws to detach the element or if not, there should be a metal protective plate at the rear of the oven to access the element screws/wiring. Replace with same.
Mar 01, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
We have a GE electric stove with a JDP 39 oven element which has burned out. How do we get the bottom heating element out to replace it?
UNPLUG the stove or turn off its breaker.
Inside the oven, trace the element back to the rear wall. There should be one screw on each side next to where the element goes through the rear wall. Unscrew that screw on each side and pull the element toward you - it'll come easily, bring its wiring behind it (this is why there must be NO power to the stove!). Detach the wiring from the element... DO NOT allow the wires to pull back through the wall, or you'll have to pull the whole range out to retrieve them.
To install the new element, just reverse that procedure.
Jul 31, 2014 | Ovens
Oven not highering up
  • 1 Turn off the power to the oven at the breaker box.
  • 2 Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
  • 3 Pull the element toward you a little bit until you see the wires behind it.
  • 4 Unscrew the leads and take the bad element out.
  • 5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
  • 6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
  • 7 Fasten the brackets, making sure they're tight.
  • 8 Restore power to the appliance.
  • Buy Performance parts.
  • Jun 04, 2012 | Belling Kitchen Ranges
    My ge spacemaker runs but does not heat items.
    HELLO.
    The problem of not-heating is from faulty element in the microwave.
    Things you will need
    • Oven Heating Elements
    • Screwdriver Sets
      1 Turn off the power to the microwave at the breaker box.
    2 Take out the screws holding the element bracket in place. These will be on the back wall of the microwave, or sometimes on the top.
    Thanks.
    Sep 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    HOW DO YOU INSTALL A REPLACEMENT TOP OVEN GRILL ELEMENT IN A XOU500SS BELLING DOUBLE OVEN
    remove the appliance so you can access the back panel. Make sure it is switched off at the wall and unscrew the nuts holding the element in place. disconnect the wires making sure to remember which wire went where. unscrew the screws holding the element inside the oven and remove. Reverse process to install new element
    Feb 22, 2011 | Belling Ovens
    How do i replace oven heat element? It is a GE Profile electric glass top range, model # JBP90WV2WW serial # ZM203767G
    Turn off the power to the oven. Remove the oven racks. Unscrew the element retaining screws on the rear wall. Carefully pull the terminals out of the back wall of the oven. Remove the wires. Place the wires on the new element,slide it into the opening,tighten the screws,replace the racks,turn on the power.
    Nov 12, 2009 | GE Ovens
    Bottom oven heating element turned white hot and broke in the middle. Can I replace myself?
    This is a common problem and easy repair. Locate the model number onside the oven door frame. Purchase the element based on the model number. TURN OFF the power to the oven. Unscrew the 2 screws inside the oven holding the element to the back wall. Gently pull the element forward. The wires will be short.Remove the wires from the broken element. Place them on the new element. Re-insert the element terminals and attach the screws.
    TURN ON the power. Bake me some cookies and send them to me.
    Jul 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
    Help.
    Unplug the range.
    Remove 2 screws holding the element to the back wall.
    Slide the element towards you carefully. Remove the wires and install them on the new element.
    Reattach the element to the back wall.
    Mar 06, 2009 | GE Spectra JBP78 Electric Kitchen Range
    Replacing oven burner element, the lower element, for a GE stove
    (I think it is 50 watts or volts??)
    Most electric ranges are supplied with 220 volts - this is, especially at 60 Hz, deadly. You were lucky this time.
    If the wires are not welded onto the element contacts, they might be so-called 'quick-disconnects' that pull straight off of blades that are part of the elelment.
    You probably haven't hurt the range with the momentary short circuit since the chassis of the range is connected to neutral or ground so you just gave your breaker a workout. BTW, I have had to replace late breakers after they tripped. They wouldn't stay reset any more even after the problem was removed from the circuit. Don't be surprised if yours doesn't stay reset; it may not be a fault causing it.
    Jan 18, 2009 | General Electric Stove/Oven/Range Chrome...
    Ge spectra jbp64, replacement bottom bake element
    Take the 2 screws out of the back wall of the oven (inside) holding the element on. Then pull the element out and it will expose the wires and terminals (2). Unplug the 2 wires and plug them on the new element and mount the element back in the oven and your fixed. (make sure to turn the power off to the oven before you start unpluging wires.
    Nov 21, 2008 | GE Spectra JBP78 Electric Kitchen Range
    GE Spectra JBP78 Electric Kitchen Range Logo
    251 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
     Fix Your Board
    Fix Your Board
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
