Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Where is the defrost drain in a Frigidaire FRT21NRG?
  • 15 Answers
Remove the bottom rear panel inside the freezer section and the drain will be under the evaporator (can't miss it).
Posted on Mar 10, 2009
Fridge defrost drain pipe plugged
Hey Michael, thank you for your post!
Based off what you have described your Frigidaire refrigerator drain pipe is plugged up. You can clear out any clog within your drain by performing a manual defrost. In order to defrost your refrigerator you would need to disconnect power from it for at least one hour. If this does not help your issue I would suggest seeking assistance from a professional technician. I hope that this information is helpful to you. -Matt
Feb 29, 2016 | Frigidaire Refrigerator White Fridge &...
How do i find the defrost drain
Hi Dennis Fish, thanks for your post!
I see you are would like to know the location of your defrost drain inside of your Frigidaire refrigerator, FRS24XGCW. Typically you can locate the defrost drain in the rear of your refrigerator. Are you currently experiencing an issue with your drain? It is not easily accessible and the best way to gain access to the drain would be to allow a professional to come out and look over your refrigerator. -Matt
Sep 28, 2014 | Frigidaire Refrigerators
Why would we get ice build up underneath bottom bskt in freezer?
because your drain is clogged and now frozen, now the defrosted frost is staying in the freezer. you must defrost the drain and than, clean the drain and insure that water can flow out into the drain pan.
Aug 10, 2014 | Frigidaire Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Ice forms in bottom of freezer on frigidaire
dependant on appliance you may have a small drain hose at the base of the appliance that drains the defrosted water away at regular intervals. Sometimes this blocks and the water that should drain away just starts to freeze over.
Mar 19, 2010 | Frigidaire Freezers
Ice forming and freezing in the freezer bottom
Need to find out if the refrigerator is going into defrost normally, about every 8 to 10 hours. If it does defrost normally, does the drain inside the freezer panel and under the evaporator coil drain without blockage? Defrosted ice, (water) should go down a drain pipe and into a pan near compressor. Let me know, Thanks, Sea Breeze
Mar 22, 2009 | Frigidaire Side By Side Refrigerator 26...
WATER IN BOTTOM OF FREEZER/TURNS TO ICE FRS28XGCB
its probably the automatic defrost cycle.there should be a drain in the bottom of your freezer,and it must be clogged.The automatic defrost keeps ice from building up in your freezer by melting it,and letting the water run out the drain.If the drain is blocked by something or clogged the water collects,and refreezes.You need to unblock the drain.
Mar 20, 2009 | Frigidaire Refrigerator Light Switch -...
Frigidaire side by side freezer- water which turns to ice is collecting at the bottom of the freezer - drain hole at the back / lower part of the freezer appears to get frozen - causing the water / ice...
this should not be happening as a heater in the freezer should eliminate this problem.first check the hose is completely clear,if it is when your fridge goes into defrost mode you should be able to feel warmth near this drain or hear the ice crackling and defrosting thence draining via the rear tube also try removing the offending ice in the drain with hot water
Aug 11, 2008 | Frigidaire Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
240 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
