Question about Apple AirPort Extreme Router
Airport extreme / Windows XP with VPN problem
I recently purchased an Airport Extreme N Router for use with a personnel MacBook Pro and an HP Laptop. I set up the router and both laptops can connect to the router for internet use with no problems (wireless and wireline).
However, I work remotely from home using the HP laptop with Windows XP, connecting to my work server through a Cisco VPN Client.
Everything worked fine with the VPN when i was using a Linksys router. Now that i've installed the Airport Extreme, i am able to connect with the VPN but it bumps me off periodically about every 15 minutes. The intenet works fine but the VPN continues to lose its connection.
The odd thing is that I am hardwired to the HP "through the Aireport Extreme" so i am not using the wireless feature. I've tried using both wireLESS and wireLINE but either way the router is conflicting with the VPN.
If i bypass the Airport Extreme and hardwire direct to the Comcast Modem off course the problem goes away and the VPN stays connected for days.
What is the issue with the Airport Extreme and the VPN Client on the Windows machine? IP address conflict?
  • Anonymous Mar 27, 2009
    I have exactly the same issue... does anyone know a work around?
  • 160 Answers
Have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Posted on Aug 26, 2009
HP Elitebook and Apple Extreme wireless connection isssue.
You may want to see if you are able to change the preamble on computer and the router to use short preamble. If you are using Windows you can go to the network connections to check the advance properties of your wireless card. As for the Apple Airport Extreme you will have to contact Apple for information if your router can change the preamble.
Jan 29, 2013 | Computers & Internet
Is too short for her MacBook Pro. -Thanks.
I would recommend purchasing a newer router that is more powerful. The Apple Airport Extreme is a fantastic router. If none of these choices work then you can either connect your Macbook via ethernet or move it closer to your router. here is the Apple Airport Extreme.
Dec 19, 2010 | Linksys WRT54G Wireless-G 802.11g...
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to open the airport option in your laptop and can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Have a windows xp desktop,and a apple macbook pro.what ROUTER
Buy a Wireless Router.
Select any of this following:
Sep 23, 2009 | Apple AirPort Extreme Router
Apple Extreme Network not picked up by Windows XP laptop.
it's a matter of who did what with whom and when they did it.
Vista came along when Apple and Microsoft had agreed to allow each other OS's to operate in each other's platforms with Intel performing the Core Duo marriage, but XP is the child from a previous generation when the two did not get along, though they knew of each other.
I know some actual marriages like that.
Didn't mean to be flippant, but XP is better than Vista in some respects and worse in this case.
Mar 27, 2009 | Apple AirPort Extreme Base Station...
Imac AirPort Extreme (0x14E4, 0x8C) to wifi
On the iMac choose Create Network... from the Airport menu. Then the Gateway laptop will be able to join the iMac's created network.
Dec 29, 2008 | Apple AirPort Extreme Base Station...
Macbook Pro airport extreme
You should only use Windows xp for running a program that is not yet available from Apple. There shouldn't be much reason to link to the net while in Windows. Also while in Windows you are wide open to any viruses that exist. Try getting your work done without getting on the net, then go back to your Apple format. There you are 99% free of viruses. … Still need to link onto the net let me know I will ask at our Apple Computer Club on Monday
May 10, 2008 | Apple MacBook Pro Laptop Computer with...
Apple AirPort Extreme Router Logo
1,248 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
