Question about GE Nautilus 24" Built-in Dishwasher
How do you replace the spray arm? The tip of the spray arm is broken and the middle is cracked.
  • 170 Answers
There should be a round assembly on top that telescopes out this usually un screws then inside there is usually a screw that needs to be removed....put it back the way you took it off and you should be okay....I have the users manual and it looks pretty standard....nothing special..
I hope this helps....good luck and good day....thank you for rating my effort....The Fang
Posted on Mar 28, 2009
How to fix the broken spray arm at bottom
Model #? if the spray arm broke off, inspect the place it attached to. you will likely have more cracks in the plastic than is obvious...
Jul 06, 2016 | Dishwashers
Middle arm loose
Hello Mike Hilgers - There are two main reasons why the middle spray arm could possibly be loose. Either it is not installed properly or the bracket that mounts it to the bottom of the rack is broken or loose. Carefully remove rack, spray arm and reposition correctly with all rack wheels inside rack slides. If you have already done so, replacement parts may need to be ordered or it could possibly be a more serious issue coming from the interior dishwasher.
Mar 03, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
Frigidaire dishwasher won't spray
Hello - Are you referring to the spray arms will not rotate? If so, do you noticed if the spray arm is cracked or broken? Will it rotate slowly? If so, you might have to remove and replace the spray arm assemblies. I will suggest verifying that there is enough water pressure coming into the unit. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board or wiring connections to the dispenser, I would suggest contacting a professional technician to diagnose the unit accurately.
Nov 21, 2012 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire gallery prof series dishwasher- arms dont work
Hello - I suggest verifying that there is enough water pressure coming into the unit. Do you noticed if the spray arm is cracked or broken? Will it rotate slowly? If so, you might have to remove and replace the spray arm assemblies.
Oct 05, 2012 | Frigidaire Dishwashers
Why is the top sprayer is not rotating?
This dishwasher uses a pulsating mechanism to push water to each of the spary arms forcing water alternatingly in each arm. This ensures a strong spray is maintained for cleaning.
The pulsating action is obtained through a ball (see item 58 in this diagram). It is possilble that this ball is either stuck or is damaged and needs to be replaced.
Sep 21, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
When dishwasher is washing and rinsing, water comes out from under the machine and goes all over the floor.
Hello
Look for leaks around the lower spray arm or soap door. Check the plastic on the lower spray arm to make sure it is not cracking down the middle. Replace the arm if you find any cracks or splits. If the soap door is leaking, it probably needs a replacement gasket.
Aug 20, 2011 | Hotpoint 24 in. HDA2000Z Built-in...
2009 year Model 2182; middle spray arm came loose; when reattached, does not turn properly or spray water; makes knocking noise with door closed.
The parts that hold the spray arm have worn out...to get it working right you will need to get a new arm and the parts that it attaches too and you will be fine...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 03, 2011 | Miele Inspira G2140 Dishwasher
Top rack of dishwasher not getting clean
The most common problem with the top rack not getting clean, is either the middle spray arm is broken and not turning (if equipped) or on some model the pop up spray arm is either clogged with debris and not turning or the pop up part is broken. Make sure to check the spray arm under the top rack, if your has one, to make sure the feed tube is attached all the way from the side to the spray arm part. If part is missing or broken, as this is often the case, you will need to determine which parts are either missing or broken, and replace those parts. If the pop up part is missing or broken, this piece comes usually with the bottom spray arm in an assembly. Your owners manual should be able to direct you further.
Good luck.
Aug 11, 2010 | Dishwashers
Du1145xtpq top spray, and upper spray arm don't
sounds like the chopper is plugged or broken. remove the lower spray arm by holding tab with a set of plyers and turn spray arm counter clockwise. then where the middle spray arm attaches at the back of tub remove screw. turn the housing on pump to the right side of the machine( its easier to pull top rack out a bit so that whole housing can move) it will turn a little bit to be released from top of pump. then take out the torx screws that hold the housing and filter on. in the sump there will be one or two more smaller torx screws remove those and remove coverings to the chopper. check to see if the mesh is plugged with food and other things. clean. also check to see if blade turn with the motor impeller. if not then the chopper needs to be replaced. good luck
Dec 03, 2009 | Whirlpool Dishwashers
Broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Mar 15, 2008 | Frigidaire GLD2445RF Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
247 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
