Question about Air Tools & Compressors
How do I adjust the pressure relief valve on my bostich cap60p-of compressor?
  • tschreib Apr 23, 2009
    J: what do you mean by "pop the cap up 1/8"? Which cap? The CAP60P-OF I have only has 2 red rotary knobs. I'm having a similar problem; my tank will only fill to around 120psi then shuts off. It used to pump up to 130psi (the max). Thanks.
    Scholar:
  • 89 Answers
YOU DO NOT ADJUST THE PRESSURE RELEIF VALVE. IT IS PROTECTION DEVICE SET BY YOUR TANK PSI. I THINK YOUMEAN THE PRESSURE REGULATOR. YOU TYPICALLY POP THE CAP UP 1/8" AND ROTATE THE KNOB. CLOCKWISE TO INCREASE. YOU MAY HAVE TO BE USING SOME AIR ( BLOWGUN? ) FOR THE GAUGE TO DROP FASTER BUT IT SHOULD DROP ANYWAY. HOPE THIS HELPS.
Posted on Mar 14, 2009
Leaking around Pressure Switch. Ordered & replaced switch but still leaking
Some pressure switches have a valve that reliefs the compressor head pressure when the motor stops and closes the head pressure relief valve when the motor runs.
There is a check valve that keeps air pressure from coming back to the compressor head and the relief valve.
I think the check valve is leaking tank pressure to the relief valve and compressor head.
The check valve is where the pressure switch mounts on to and it mounts threaded on to the compressor tank.
Try replacing the check valve
Nov 01, 2015 | Craftsman 33 gal Air Compressor 6 hp...
POP OFF VAVLE ON HEAD KEEPS POPPING UP
The over-pressure relief valve may be defective if the valve is opening before the desired tank pressure is reached. If not, then the shut-off pressure adjustment (if there is one) may be set wrong. You'll need to find out from the manufacturer exactly what static tank pressure the compressor is designed to provide and then determine if it is working correctly. If so, then the relief valve might be defective. DO NOT attempt to defeat the relief valve under any circumstances - it can result in compressor damage or a dangerous tank failure.
Oct 06, 2014 | Porter Cable 175 PSI 80 Gal. Oil-Lube...
Is the reed valve part of the pressure switch
relief valve should only open in a over pressure condition. If it is opening prior to reaching pressure ....replace it.
May 21, 2012 | Air Tools & Compressors
How do i adjust the pressure relief valve so it quits poping out befor the compresser shuts off
There is no adjustment on the relief valve. They are preset at the factory. You might have a problem with the pressure shut off being set too high on the upper limit causing the pop off to activate before the motor shuts off.
Mar 17, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have a C2006 Type 4 Porter Cable pancake compressor which will build pressure all the way up to 150psi then cut off as it should but there will be a loud hissing and pressure drop until the cut on...
first you have a reciprocating pump and the hissing you ear probably comes from the unloading valve on the pressure switch(it will look like a bike tire valve)if there is air coming out the valve when the compressor is off it probably means you have a bad check valve.This valve is use to unload the pressure inside the pump for an easy start .a motor always drive more amps on start up if you cant unload this pressure you will trip the overload(you probably have a reset button on your motor)check the specs on your pressure relief valve ,its a small pump maybe its just adjusted to high.in this case your pressure relief valve will open .If the pressure is fine and there is air coming out the relief valve then you have to replace it!to adjust your pressure turn the screw on your pressure switch clockwise to increase and counterclockwise to decrease .usually you have a 30 psi between cut-in and cut-off called the pressure differential.It can be adjusted on some pressure switch.be sure you put some teflon tape on the treads if you replace something to avoid air leaks.hopes this help!
Jan 23, 2011 | Porter Cable C2002 150 Psi 6 Gal...
How do I adjust the cut-out pressure on my DeWalt D55140 compressor? The relief valve is activating at 140psi before the compressor cuts off.
I had the same problem. The relief valve loosened up after a couple years of use. Right around the center pin in the relief valve is a ring that has a slot in it that you can fit a small straight blade screwdriver into and tighten in a clockwise direction. This should tighten the spring on the relief valve and raise the pop-off pressure above the 150 psi setting of the cutout switch.
Apr 10, 2010 | Dewalt D55140 Heavy Duty 1 Gal, 135 Psi...
How do you adjust the pump pressure valve on a Emglo model KU
do you mean the relief valve. it is factory set for your safety and the sefety of the equiptment. also known as the safety relief valve.
if you are talking about working pressure you need to adjust that with the air regulator.
if you are talking the cut out pressure sensor, again this is also factory set for safety. if your equiptment is designed for 110 psi then when your resivor reaches that set point it should cut the motor off and stop running.
Feb 21, 2010 | Air Tools & Compressors
My Bostich CAP60P compressor will build pressure to about 40 pounds (tank pressure), and then keep running but not build more pressure or build it very slowly. No leaks.
sudden loss of capacity like that usually indicates broken or leaking valves in the head, or a blown gasket between inlet and discharge side of the head. if nothing is found there, then look at the piston and or cylinder bore for damage.
Jan 17, 2010 | Stanley Air Tools & Compressors
Bostitch Air Compressor cap60p-of will not shut off
hi mate you can try and adjust it but if this problem has just started then you need a pressure switch replacement
Aug 29, 2009 | Air Tools & Compressors
The compressor relief valve keeps popping, compressor runs
What pressure is it popping off at? You might have to adjust the pressure switch to a lower setting.
Apr 01, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
324 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
james allen
james allen
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
