Question about Coleman Heating & Cooling
I have an old 1985-86 coleman central heat and air need manual
I have an old 1985-86 coleman central heat and air unit in my 4 bedroom house. I can't find the manual for it. I also need to know where the air filter is so I can change it. I just bought the house last week.
    Guru:
  • 462 Answers
The filter is located before the blower if your Coleman is in a mobile home it will be in the door facing. If it is a standard ac/heat application and a regular residential furnace the blower in the cabinet on down flow (ducts in floor) will be above it and possible in the duct connecting in the top. If its the other way (ducts in ceiling) it could be right under the blower. Either of these could have a filter cabinet on the furnace or could have a filter grille at the end of the return air duct (where the air is sucked in).
Posted on Mar 10, 2009
I submitted a ? Earlier in reference to the igniter on my Coleman central unit w model PAC036H1021A.. My unit stopped blowing heat and was blowing cold air only in the house. It stopped last night and I...
It sounds like you may have electric heat. With that being the case and your description of a burning smell indicates an electrical problem. Since you did get it to start heating it sounds like a possible heat relay problem. I have also found burned connections and I was able to repair them and get the heat strips working again. If you know an air-conditioning and heating technician or electrician you should try to get assistance. The voltage in these units is dangerous and one mistake could only make things worse.
Feb 13, 2015 | Coleman Heating & Cooling
I would like to know how many square feet a Model # BRCQ0421BD Serial # 990905429 Coleman Central Air Conditioning Unit will cover. The unit supply is 208-230V 1 PH 60 Hz 10.8 RLA 97 LRA.
The Old Rule of Thumb is 400 square feet per ton, but you really need to do a heat load calculation to be safe. A lot of windows on the west or south side of the house will really increase your load and you may need a lot larger unit. Insulation also changes your load so you may be able to cool a larger area. You may be able to get the Heat Load Calculation Form either online or from Johnstone supply. They are on the internet.
Aug 07, 2012 | Coleman Heating & Cooling
Replacing a Coleman with a Duotherm, can the same thermostat and controls be used?
Hi, yes you can use the same thermostat if you are replacing the unit that has the same sequence of operation. What I mean is, if the old unit is a gas fired furnace and outdoor condenser split system for the a/c you can use the same controls, or if its a package unit. Now, if you are installing a heat-pump unit in place of a gas fired central unit, you will need to pull more stat wire and buy a heat-pump thermostat to make it run.
Shastalaker7
A/C, Heating Contractor
Oct 12, 2010 | Coleman Mach III Air Conditioner
Where can I find a manual for my coleman cam II central air conditioner for a mobile home? I recently purchased the mobile home and would like to know what steps to ntake to make it work at its best. ...
Check the website for Coleman/Intertherm for a manual, you will need the model and serial numbers of the unit. The filters for these typically sit on top of the unit, some come with frames, some lay directly on the coil. If you can't find a manual on the website or by contacting the company, check the yellow pages some towns have a mobile home supply house that would be able to help.
Aug 30, 2010 | Coleman Heating & Cooling
ENGLAND, UK. DOMESTIC HOUSE CENTRAL HEATING. Baxi Bermuda
try bleeding the radiators in the order of downstairs first and then the upstairs and try to bleed them in the order they fill, trapped air can take a while to escape, a good sign on a radiator is the bottoms being warm where the tops( where the air is trapped) stays cooler, a sure sign to which radiator needs bleedin, hope this helps, colin
Apr 02, 2010 | Heating & Cooling
I have an '06 model combination cooling and heatin
For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
Dec 22, 2009 | Whirlpool Heating & Cooling
When we turn on the central air there is a strong burning smell...like burnt toast but way stronger. IS it safe to remian in the house?
Is your central air furnace or electric heat. Electric furnace sometimes have electric strip sequencer stick in the closed positions leaving on one strip of the electric heat. Get a service tech as soon as possible to check this out. Any smells from a central unit need to be teken care of promptly. TURN OFF unit you have it checked for your safety. Rus
Jun 28, 2009 | Coleman Heating & Cooling
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
296 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
