Question about Canon Office Equipment & Supplies
Error code E000019-0000
The copier say's to turn the power off anf back on but the error code will not clear. Can you give me a little more info on the error code
Waste toner container is full.
Posted on Mar 12, 2009
We have an error code E000004-10 and the machine will not turn on.
This is a problem with the fuser not getting hot enough. Try resetting the error code by going into service mode. Press additional functions key, then the 2 & 8 keys at the same time, then the additional functions key again. Select copier, then function, clear, then err, press OK. Power down the copier and power back on. If the error returns record the numbers after the dash. This is an important sub-code that tell you exactly what the problem is. The 0010 code says that the copier was turned of and back on without clearing the code first. The indicates that there may be a problem with the heater, DC controller, the heater power supply, or connectors on the rear of the fuser drawer. Hope this gives you some ideas of what to do.
Feb 02, 2011 | Canon imageRUNNER 5570 Copier
Getting an H4 Error code on my Xerox XC1045 copier. Any Suggestions?
This will most likely clear it. If not then the heat rod in the fuser most likely went bad.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. Program the copier as if you were going to make 14 copies.
  7. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  8. Run a test copy.
  9. repeat 1-7 more than once to be sure it has worked properly.
There was incorrect info in this I copied and pasted. I corrected it.
Feb 23, 2010 | Xerox Office Equipment & Supplies
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
My ricoh 1022 after puting power on it shows error code sc542
What code? Try entering service mode then turn off copier and turn it back on. (push these buttons in sequence Clear modes (yellow) 1 0 7 then hold the red stop button for 5 or so seconds you are now in test mode
Jun 10, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
XC-830 copier Displays fault code H-3
Give this a try , if it continues you will have to replace the fuser.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy
Aug 07, 2008 | Xerox Office Equipment & Supplies
E000001-0003
first verify that the fuser drawer is inserted correctly and there is no debris in the fuser connector. Also check the fuser for paper wraped around the roller. Next, enter service mode ( 'additional functions', 2&8 same time, 'additional functions') press copier->function->clear->err->ok. Then power cycle the device. NOTE: Only do this procedure ONCE! Repeatedly resetting this error can cause the fuser to melt down or even cause a fire. Allow the fuser to cool for at least 20 min before attempting again. If this does not work then there is a problem with the fuser heater or temperature sensing and a new fuser or additional repairs may be required.
Jul 26, 2008 | Canon imageRUNNER C3200 Copier
Canon ir 6570 error
Im new to this forum. I have an IR6570 giving me an error code E808-001, please help,
May 15, 2008 | Canon imageRUNNER 5570 Copier
5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Jan 08, 2008 | Canon imageRUNNER 5020 Copier
279 people viewed this question
old marine
old marine
