Question about Whirlpool Duet GHW9150P Front Load Washer
Canceled the clean washer cycle, got "INT", won't work now
It appeared the clean washer cycle was stuck at 1 minute, so I hit pause/cancel and "INT" appeared on screen. I tried to restart, tried to cancel, tried to open door. Nothing is working.
  • 107 Answers
Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
Posted on Mar 13, 2009
  • dwsirk21
    dwsirk21 Sep 18, 2012
    Mine is doing the same thing but it said SUD before an when I try to cancel it, it then says Int an it won't reset
Codes f26 and then f27 for maytag model MFH 0710
F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    My frigidaire dyer comes on then the pause message appears. These are new appliances.
    Hello barbarada180 - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
    Jan 02, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
    My maytag commercial washer display a code F26
    This error code indicates that the door needs to be opened and closed.
    The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
    NOTE: If the error remains on the display, and the condition above has been checked, call for service.
    Oct 23, 2012 | Washing Machines
    Fault code f26
    Jul 30, 2011 | Maytag Washing Machines
    The washer stops half way through all cycles and displays "oL" .
    Error oL means overload.
    If the "oL" error code appears, the washer has been filled with a load that is too large for its capacity, causing it to drain.
    *Remove some items from the washer and add more detergent since the previous amount will have drained with the water.
    *Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle.
    If Pause/Cancel does not work:
    *Unplug washer or disconnect power for one minute.
    *Plug in washer or reconnect power.
    *Re-select the cycle and press Start.
    Hope this helps.. :)
    Jun 08, 2011 | Washing Machines
    I hit cancel in the middle of a cycle and now it keeps saying F1
    From the maytag website:
    To remove the error display, press Power/Cancel or Pause/Cancel twice.
    If Power/Cancel or Pause/Cancel does not work:
    Re-select the cycle and press Start/Pause.
    NOTE: If the error remains on the display, call for service.
    Sep 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
    Reset wash cycle
    Changing Cycles, Options and Modifiers
    Not all Options and Modifiers are available with all cycles. Cycles,
    Options and Modifiers can be changed anytime before HOLD TO
    START is selected.
    Options and Modifiers can be changed anytime after HOLD TO
    START is selected and before the start of the selected Option or
    Modifier.
    To cancel a cycle and select a new cycle
    1.
    Select PAUSE/CANCEL twice.
    2. Select desired cycle.
    3. Select the desired OPTIONS.
    4. Select HOLD TO START (for approximately 1 second) to
    restart the washer at the beginning of the new cycle.
    To cancel a cycle
    1.
    2. The washer powers down, the door unlocks, and clothes can
    be removed.
    NOTE: If the water level or the temperature is too high, the
    washer will drain automatically before the door unlocks.
    To change Options or Modifiers after the cycle has started
    1.
    Select PAUSE/CANCEL.
    2. Select the desired OPTIONS or MODIFIERS.
    3. Select HOLD TO START (for approximately 1 second) to
    continue the cycle.
    To drain the washer manually
    1.
    2. Select DRAIN/SPIN.
    begin the drain.
    4. When the spin is complete, the door unlocks. Items can be
    removed from the washer.
    Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    672 people viewed this question
    Dan Webster
    Dan Webster
    Sal De GO PATS
