Question about Plumbing
WHEN FAAUCET COMPETE SHUT DOWN AND STILL LEAKING
WHEN FAAUCET COMPETE SHUT DOWN AND STILL LEAKING AND I HAVE DELTA FAUCET IN KITCHEN SO WHAT IS THE PLM ??
  • Robert marquette May 11, 2010
    Internal to the valve body are spring loaded plungers which can wear out and are replaceable. What type (not brand) of faucet is it?
    President:
  • 2,692 Answers
Delta Single lever? Remove handle by loosing the allen screw . Tighten the spanner clockwise. If that doesn not fix problem, turn water off, remove spanner nut. Remove whole assembly. Take to plubming supply and latch us for rebuild kit.(two rubbers, two springs,. a spanner wrenchand an allen wrirenc and maybe a new spaner nut) Install same.
Posted on Apr 25, 2009
Just installed a Delta Touch20 kitchen faucet. When using the touch feature the faucet turns down to a trickle but does not completely shut off, even after several minutes. Any suggestions?
Check installation manual if there is some indication about some kind of advice for this case. If there is no indication for the user, most probably your Delta Touch20 kitchen faucet is defective. Check your warranty terms about how you can return it to be changed or send it for service, so probably you'll have to uninstall it.
Jul 03, 2015 | Delta Plumbing
Leaking kitchen facet by delta
Great design! Even I think that it's a must have kitchen appliance specially for modular kitchen users.
Aug 24, 2013 | Delta Model 470: Signature Kitchen...
How to fix a leaking faucet
want to extend my delta tap about 5inches how do i do it?
Sep 03, 2012 | Delta Model 470: Signature Kitchen...
My delta faucet 172-sswf waterfall single handle kitchen faucet is leaking at the handle or lever how do I repair it?
i forget what the piece is called exactly but if you go to home depot or lowes or where ever and give them the type style and brand of your faucet and tell them what it's doing they will set you up with the new part. it's sort of a core type piece with rubber o-rings on it
Jul 13, 2012 | Delta Faucet Delta 172-SSWF Waterfall...
Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
The parts page on this link will give you a break down and hope this will help.
http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
Dec 30, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Mar 24, 2009 | Delta Model 470: Signature Kitchen...
Plumbing Logo
251 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
