Question about Treadmill Doctor Pacemaster Platinum ProClub Treadmill Deck by Pacemaster
Pacemaster treadmill err 133 - Treadmill Doctor Pacemaster Platinum ProClub Treadmill Deck by Pacemaster
  • Treadmill Do... Master
  • 6,694 Answers
If you wish to get some details About treadmill Error codes ; check the site linked here. Pull up older posts almost all treadmills are listed . Surf the site with patience.
http://electro-medical.blogspot.com/
Posted on Mar 07, 2016
    New Friend:
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Posted on Sep 07, 2013
  • Chris Shannon
    Chris Shannon Nov 27, 2017
    I am just wondering which RJ45 Connector you re-did? Was it the motor module or the upper panel and how did you tell that it needed to be redone?
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
Pressed express incline then machine went to top incline and received error 306. What is the problem?
Err 306 - Indicates power supply problem at start up.
1. Check all wiring for proper connections and damage
2. Replace the lower power supply board.
3. Replace the drive motor.
Recommended Parts: lower power supply board, wire harness.
I would suggest you get a tech out first. 877-805-1030
Dec 24, 2013 | PaceMaster Silver Select XP Treadmill
Error message 133
It is an error code that refers to a black cable that attaches to the main circuit board located by the motor. It looks like a fat telephone wire. Unplug it and reinsert at both ends but try the bottom one first as it is easier to get to. If doing this does not work you can meter the pins on the cable to make sure that there is not a problem with it or you can replace it. If the cable is good and you continue to get that error then you will have to replace the power circuit board. I hope this isn't the case because they cost around $450.
Jan 25, 2013 | PaceMaster Premiere EXT Treadmill
Bronze Basic Treadmill Your question about Bronze Basic Treadmill has been posted. i have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks solli...
yes there are some reset button see your owner manual and do it. if you do not have owner manual download for free
LUBE the deck belt and rollers bearing inmediately.
www.fitness.manualsonline.com
Happy New Year. God bless you
Jan 02, 2013 | PaceMaster Bronze Basic Treadmill
I have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks solli On 2013-01-01, at 1:32 AM, FixYa.com wrote:
RESET the machine and try again.
However if you can get again the code, Lube the deck belt and rollers bearing very well.
Test the motor and controller motor see the block diagram
see the video and proceed according.
Jan 01, 2013 | PaceMaster Bronze Basic Treadmill
I have a pacemaster silver it is givin me a err code 304
Dear Sir:
Please RUN the software calibration, for easy diagnose and troubleshooting and fix the problem.See the instruction manual. If you do not have go for free download: www.fitness.manualsonline. com or www. iconservice.com
sincerely. God bless you
Apr 25, 2012 | Exercise & Fitness
Treadmill Doctor Pacemaster Platinum ProClub Treadmill Deck by Pacemaster Logo
731 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
fordexpert
Marvin
Marvin
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
