Question about Oregon Scientific MP120 MP3 Player
I removed all the settings files from the player HD, then I copied them back again and the mp3 cannot initialize anymore..how could I fix this? thx
Archos AV700 I/O Error
Offhand, I would suspect that the remaining files were somehow corrupted. Is it possible for you to verify those files using the external HD and a PC?
Either that or the format of the Archos AV700 was not that "clean" and would require a redo.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 15, 2008 | Archos AV700 Digital Media Player
Tip
Sync iTunes M4P Music to Non-Apple Players like Walkman, Windows phone 7, Droid,...
Quoted from: Convert m4p to mp3
The Apple iTunes Music Store sells AAC, M4A, M4B, M4P songs and Audible audio book online, accounting for more than 80% of worldwide online digital music sales. The AAC, M4B and M4P songs sold on iTunes Music Store are encrypted with Digital Rights Management measures, while M4A is for the unprotected content.
So, if you want to listen to M4P music with other mp3 players such as Sony walkman, Zune(HD), PSP(go), Creative Zen, Sansa Fuze, Android phone(Nexus one, Droid(X/2)), HTC Phone(HTC EVO/Desire/HD2/HD7) and play itune music on xbox 360, PS3, windows media player, window movie maker or share them with your friends, you have to convert M4P to an open format like MP3.
In this text, i will share two methods to convert M4P to MP3
Method1: Burning and re-import. (M4P->CD-> MP3)
1. Burn the the M4P's onto a CD.
2. When it has finished burning, enter that CD into your computer again.
3. Click on "Audio CD" under "source" on the left side of your screen in itunes.
4. Then right click on the track you want to convert to an MP3.
5. Select "convert to MP3"
6. Once it has finished converting, copy that file to somewhere else on your computer (ex. C/Documents and Settings/User/My Documents/My Music)
7. Copy it again from where you just pasted it, and paste it into your MP3 player. (this is at least how to do it for my Nomad Jukebox).
Method2: Convert M4P to MP3 derectly with Daniusoft DRM Converter
Daniusoft DRM Converter is an easy M4P music Converter that can convert M4P to MP3 with one step and the speed is up to 27x. It also can convert protected iTunes videos, movies M4V to MP3, WMA on Windows PC.
Simple Steps for converting M4P to MP3 with Daniusoft DRM Converter:
Step 1: Load DRM M4P files
Click "Add" to load DRM AAC files, you are allowed to import all supported format music files:M4P,AAC, M4B, M4A, WMA, WAV, MP3, OGG, MKA, AA, AAX, etc.
Step 2: Setting output formats
Click "drop-download" list at the bottom to select output format for your M4P files. You may customize the output settings for AAC files. Choose an output format from "Convert to". Click the "Settings" button for detailed settings of "Bit Rate, Sample Rate, Encoder, Channel "to make your output with high quality.
Step 3: Convert DRM M4P to MP3
Once you've finished all the settings, click "Start" button to beginning your conversion. After conversion, you can click the "Find Target" button to open the output folder and find the converted files.
Note: You can drag and drop all your music files to M4P to MP3 converter at a time, then do something else till it is finished.
Now you can own the music forever and play it on your mp3 players such as Sony walkman, Zune(HD), PSP(go), Creative Zen, Sansa Fuze, Android phone(Nexus one, Droid(X/2)), HTC Phone(HTC EVO/Desire/HD2/HD7) as your will.
remove drm from wmv ' iplayer ripper ' remove drm from itunes 10 ' itunes to droid ' Transfer itunes music to htc evo 4g ' wmv to ipod touch 4g ' drm removal ' convert m4p to mp3 ' amazon video on demand ipad ' remove drm from itunes ' remove drm from nokia music store ' m4v to droid ' iTunes to galaxy s tab ' sync iTunes to walkman
on Oct 24, 2010 | Cell Phones
My new mp3 player (2gig) wont play music anymore. i turn it on, and on the screen it says "music" when i press "m" it says "initializing" and then goes back to saying...
You may try restoring your mp3 player to factory settings and then loading the music back. Make sure you have a back up of your files before restoring though.
Mar 07, 2011 | Eclipse CLD2 MP3 Player
Just not in the manual! I wish to clear all existing tracks and load it up afresh.
If you follow the instructions on page 19 of the manual, Connecting to PC and transferring files, you'll see in step 5 that
5. You can copy any files including MP3, JPG, and transcoded video files encoded by JetAudio VX to and from "iAUDIO" Drive.
I recommend you try to just remove all the mp3 files in your folder at once, by control clicking or shift clicking to select multiples that you want removed. Unless of course there are simply too many.
In that case, have you tried restoring the player to factory settings, as described on page 44 of the manual? (pictures not shown here)
5.1. Resetting the Player to Factory Default Settings
iAUDIO F2's settings can be deleted and re-initialized to Factory default settings.
1. After the player is turned on, select the Music mode.
2. If a music file plays, pause at the playback screen and do as shown below.
3.When, initialized, the Language setting screen will appear when the player is turned
- If the player operates improperly, press the "RESET" button at the bottom of the player and then restart the player. If malfunction continues, please initialize the player to Factory Default setting.
See this link for an online manual.
That's my recommendation. I'm going by the manual, though, as I don't own one of those players...I hope that's the information you were seeking.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 10, 2011 | Audio Players & Recorders
WHENEVER I SWITCH ON AND TRY TO PLAY ANY MUSIC FILE IT SHUT DOWN.EVEN I FORMATTED IT ONCE
First reset yours by the Back button;
If not solved;
Reset again by the button, the On the Computer by Fat32 Format, and then Copy the Initial Files that were on your MD when you Bought;
Good luck
Nov 01, 2009 | Sony Network Walkman NW-E005 MP3 Player
Samsung yp-u3j ZB/XEU freezing/computer not recongising after i deleted files from the device
Hi...I find the answer...Push and hold rec button and button for holding...And it will start..
Jan 26, 2008 | Samsung YP-U3JQB MP3 Player
Tge mp3 mz111 player
Same problem...... Whats up with this...
Dec 26, 2007 | Sears TGE MP3 Player
Hard drive
I would be willing to bet your hd has crashed, you could try to fix it check ebay for one that works
Dec 12, 2007 | iRiver H10 MP3 Player
Screen displays..(internal media as...)
Dude, remove the batery, then, connect your mp3 in your computer, select in Windows menu: Format...but format in FAT...not in FAT32..or Ntfs...then, disconnect and connect again...put music...and thats it...¡¡¡ enjoy again...
Bye..
Oct 14, 2006 | TDK MOJO X 128 MB MP3 Player
Oregon Scientific MP120 MP3 Player Logo
54 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
