Question about Whirlpool LER7646E Dryer
Dryer smells burnt, thought we saw light smoke. Don't have owner's manual.
Something is on the element. possible fire hazzard, but usually burns a hole in element, rendering it useless.
Posted on Mar 11, 2009
Whirlpool Gold Ultimate Care II Gas Dryer takes to long to dry
sounds like ur t-stat is bad or maybe a thermal fuse. hard to say w-out diagnosing in hands on.
Jul 25, 2013 | Dryers
2000 buick lesabre ac compressor smoking/not working
either way i wd. replace the assembly! ck. alll the idelers and tentioner pulleyys
Jun 06, 2012 | 2000 Buick LeSabre
MOTOR SMELLS OF BURNT MOTOR WINDINGS. iS IT NORMAL
No, the pump works while spinning. The burnt smell is probably the belt, especially if your wife saw smoke. Did she put a big load in it at the time?
The belt will slip until the tub catches up with the motor. If there is a heavy load, it can burn the belt up. I would replace it. Make sure the idler pulley on the motor moves freely also.
http://www.partselect.com/MultiModels.aspx?ModelNum=ALW480DA&searchTerm=&RefineSearch=0
Jan 22, 2010 | Amana ALW480DA Top Load Washer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Reduced RPM and smell smoke
Could be electrical problem, (brushes burnt, armature grounded or bearings starting to seize up) I don't think that I would use it till the problem is fixed. Could cause or create more expensive repair. Let me know and I will try and help
Jul 20, 2009 | Craftsman 10" Table Saw
Dryer smoking, burned rubber smell
if the rug has a rubber side it will melt make sure dryer is clean and no left over burnt material ..
Sep 18, 2017 | Dryers
Packard Bell no longer switiching on or charging
sounds like a bad dc port, but if it was smokeing and has a burned smell i m betting it burned the board
Dec 17, 2008 | Computers & Internet
Dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Apr 12, 2008 | Dryers
Dryer smelling hot and smoke detector goes off
clean the venting going to the outside and the dryer really ahould be taken apart and delinted to avoid a fire if the unit is older
Mar 21, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
219 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
