Question about Belkin (F5D7230-4) Router (587009)
Do i connect my belking router to a modem? - Belkin (F5D7230-4) Router (587009)
  • 170 Answers
Yes, it will go Cable or DSL modem, router, then computer either wirless or hardwired
Hope this helps, please rate accordingly if it did
Thanks,
David
Posted on Mar 10, 2009
I am trying to connect my Belking G Wireless Router with Comcast what do I need to do to make this happen?
Connect the ethernet cable from back of cable modem to the LAN port on the back of the Belkin Router. Next you will need to run another Ethernet cable from port 1 of the router to a computer. Type in the address "192.168.1.1" or "192.168.0.1" into the address bar on Internet Explorer and setup your SSID for the network and any security you want on the network (optional but recommended). Once this is complete you will only need to connect to the network (the SSID you chose during setup) on your PC.
Jul 11, 2011 | Computers & Internet
I recently went back to cable broadband and am using my Belking wireless G plus mimo router again. Did not have a problem when I last used it. Now I have to reset the rounter every day to get my WIFI...
Try removing power from the modem and router for 30 seconds, plug the modem back in first then the router. Also could be WPA, have you tried to take all security off and see if it makes a difference? Made sure the os is current with updates, some older sp for xp for instance had an issue with WPA.
Oct 25, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My house computer is being fixed out of the house, now my wireless computer isnt working, i have to connect to the phone connection. Is that the way it should be?
Check All your connection Reset your Router in the back you will see a little hole with a button press on it for 10sec.. Then got in your Sitting Control Pannel add and Remove ...Remove your Belkin software and re start your PC then re install your belking software for Any PC You may have a 4 hub conection ... So make shure your Modem are connected on the right Hub on your Router and the phone line to the modem Because See The modem tranmit is data to the router the transmit on any pc connected ony your Router ...good luck
Sep 22, 2010 | Belkin (F5D7231-4) Wireless Router
Flashing amber modem light on belking n wireless router
Actually there is no problem with the Modem
First Get the following Information from your ISP
1 ) The Connection Type
2 ) If it is PPPoE then Get the user name and Password
Step 1 : Connect Modem - Router - Computer (Wired)
Step 2 : Open RSP By typing 192.168.2.1 on the Address Bar of the internet explorer
Step 3 : On the Left Side Under Internet WAN Click
Connection type
Step 4 : Leave the Password Blank and click Submit
Step 5 : Select the connection type as given by the ISP
Step 6 : Click Next
Step 7 : Type Username And Password for PPPoE ,Click Apply Changes
Step 8 : There is no need to type Any Host Name for dynamic Click Apply Changes
Step 9 : If it is A Cable connection then
Step 10 : On the left side Under Internet WAN Click MAC Address
Step 11 : Click Clone
Step 12 : Click Apply Changes
Step 13 : Restart the Router
Step 14 : Check the Internet Status
Jan 11, 2010 | Belkin Wireless-N Wireless Router with...
Belking wireless router can't see my comcast cable modem
then login to router setup page with 192.168.2.1 type this one in the address bar of ur browser
then u will see router setup utility
then click on the restore factory settings on the left hand side under UTILITIES
it will ask u for password leave it blank and click on submit
then click on restore factory default
once it is completed then on the rite top corner u can find the internet status --- it has to be connected or else
u can unplug the modem and routers power cord and wait for 1 min
the plug the powercord of the modem first wait for few seconds till the light are stable on the modem then plug the powercord of the router
then ur internet light should be solid on the router
Dec 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need help connection my motorola surfboard modem, to my belking wireless router... I've attached all wiring and powered down everything like the instructions say, but my router still doesn't seem to be...
you will need to set up the router manually.
First make sure that your computer is able to go online when connected to the motorola modem only.
Click Here for step by step solution
Nov 04, 2009 | Arris SURFboard SBG900 Wireless Router...
Have a belking N+ router and cant get past my cable modem, any 1 know a cure.
If you connect the computer directly to the modem , does it work ?
If that is working then the modem must be working you will need to check the settings of the router.
Click Here for more info about how to set up router.
Aug 06, 2009 | Computers & Internet
Belkin Wireless N+ router - can't connect to Etisalat in UAE
you could try updating your router's firmware.. it fixes a number of bugs and makes the web interface multi-lingual. This version supports English, German, French and Spanish.
Feb 10, 2009 | Computers & Internet
My Belkin Software!
Try the Belkin WEB site or Google the driver
May 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Installing wireless G router
Yes, you do need a modem (DSL, Cable). This router does not function as a modem.
Oct 01, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Belkin (F5D7230-4) Router (587009) Logo
54 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
