Question about Xerox Phaser 8200 Laser Printer
PHASER 8200N ERROR CODE 15,004.45:7829
  • andre_lee Mar 12, 2009
    I did what you said and there were no lights illuminating from the printer.... please send instructions for lamp replacement.
  • 2,072 Answers
There are 2,,,, 150 watt halogen lamps in that machine that heat the drum. One or both have blown. How to be sure is, turn the lights off in the room of office the machine is in, turn the machine on, and look into the right side fan slots. After a minute or 2 you should see a glow inside the machine. ( You won't) those lamps are bad. Xerox will want to sell you a new drum heater for over $200,You can go anywhere that sells halogen lamps. Lowes, Home Depot or just about any place that carries lamps will have them. They are less than $15. I recommend , if you can find , the Sylvania lamps that are rated for 130 volts and are vibration protected.
If you want to try and replace them. let me know I will send you written instructions. Should take an hour or so to replace.
Posted on Mar 11, 2009
  • Rick Kasper Mar 12, 2009
    To skip the if you want to I will send you instructions, I will send them now.
    First of all you will need Torx bits or drivers to remove the covers etc. I think mostly you will need a number 10 and 15 size.
    off you want to remove both side covers, there is one screw on the top
    back of the covers, and another on both covers, top front, you have to
    open the front paper path door to access the front screws. Then about
    the middle of the covers pull up and outward, they will kind of pop
    off, but that's fine, they have tabs on the bottom that can be pesky.
    Remove the paper tray, the green maintenance tray and set aside.
    remove the 2 green rails that the maintenance kit rides on. They both
    are held in by one screw. It will take some manipulating to get them
    out, but basically you push them slightly back, inward and twist
    slightly until they come out. TAKE NOTE of how the leaf springs are on
    the rails, A hint when putting them back in, is to take some scotch
    tape and tape them on the side to keep them in place, You will see what
    I mean when you remove them. But its much easier to get the rails back
    in when those springs are taped to the side. And no worry about
    removing the tape afterward, I will have no affect on the machine if
    its left in.
    Next, you look up and you will see a stainless steel
    curved plate. About 10 inches long and 3 inches high. There are 2
    screws on the top of it that must be removed. There are 2 tabs on
    bottom, Once the screws are removed it just lifts out.
    Now about
    midway up the paper path is the registration rollers. First, you have
    to go, ( looking from the front of the machine) to the left side of the
    machine, You will see a electromechanical clutch on a shaft with a 2 inch
    black gear with a belt attached. Remove the clip that holds the clutch
    on, slide off the gear and just let the belt drop in place.
    return to the front,The assembly is stainless steel, you will see a
    couple of rollers on it and some paper path actuators. There is one
    screw on the right side of that assembly that you need to remove, and
    on the left side, just by the bearing there is an "E" clip holding the
    bearing against the frame. remove the screw and the clip, Then move
    that transport CAREFULLY to the left and out. Be very careful to keep
    the 2 pieces together, there is a switch actuator that can be easily
    broken. So please take caution. On the right side, there will be a
    bearing that WILL fall out, and drop down into the paper feed area.
    Trust me it will do that. Just locate it and pick it up. When replacing
    that transport. I suggest, ( unless your considering suicide LOL) Put
    some white out or a little glue on the outside of that bearing when you
    press it back into the frame. Otherwise, IT WILL keep falling out and
    really try your patience. Just trust me on that one.
    Now, look in
    the front , just above where the maintenance tray would go. You will
    see 2 screws, about 10 inches apart, They will be surrounded by a
    beige/brownish plastic. Remove those 2 screws, they hold in the heater
    assembly you want to repair. When you remove those screws it will not
    yet come out, wiggle it a bit and look on the right side so you can
    easily determine the connectors, plugs you need to remove. Some have 1
    some have 2.
    Once you do that, slide that heater assembly downward and out. You will see the 2 lamps in there.
    those little spring metal clips out,, replace BOTH lamps. Use some
    emery cloth to clean the contacts. Clean the reflector behind those
    lamps before replacing . That will make the heat transfer more
    Once those are in , in reverse order reassemble. Just be
    cautious replacing that registration assembly so you don't break the
    black actuator.
    It's really not hard, just takes some time. Give
    yourself an hour to an hour and a half. But that is your problem I
    guarantee it.
Paper jam error comes up and can't clear it. Doesn't appear to be any paper stuck in printer anywhere
please double check again your printer by re-opening it.
look very carefully maybe there was still a small paper inside your printer.
after that try to turn it off your printer then afer 5 mins yiou can turn it on again.
any changes happen and further question don't hesitate to contact me.
Mar 21, 2009 | Xerox Phaser 8200N Printer
I have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Mar 11, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Error code 19,003.48:75856
That is a print head calabration fault. 99 percent chance the print head has failed. That would require replacing hte print head.
That is a common problem on the 8500. Look for a dealer in your area if you want to repair is. Xerox will charge over $200 to show up and $750 for the print head.
Jan 29, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Jan 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8500N Printer Error 09,037.45:9085
You have to go into Diagnostics. Once in Diagnostics arrow down to function menu.
Then select
Then arrow down to ClearISCfaults hit OK
follow instructions on screen.
Nov 24, 2008 | Xerox Phaser 8500/DN Printer
Phaser 8400 error code
That is related to the print head heating. Normally one of the print head heaters fails which requires replacement of the print head. The other item I have seen fail and cause that code is the electronics module. Both are very expensive.
Oct 09, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8200N hangs on warmup
Flat Rate - Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer is Now offering Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer at a flat rate. Basically we repair any problem you may be having with your Phaser Printer for a flat rate. The flat rate covers cost of parts, labor and travel expenses. The flat rate is all you will pay to get your printer back in order. No hidden fees or charges. We show up! We Repair it. You pay us the rate for you model.
Our Flat Rates:
MODEL: Tektronix Phaser 840 Color Printer Repair - $159
MODEL: Tektronix Phaser 850 Color Printer Repair - $159
MODEL: Xerox Phaser 860 Color Printer Repair - $159
MODEL: Xerox Phaser 8200 Color Printer Repair - $159
MODEL: Xerox Phaser 8400 Color Printer Repair - $179
MODEL: Xerox Phaser 8500 Color Printer Repair - $199
MODEL: Xerox Phaser 7700 Color Printer Repair - $209
MODEL: Xerox Phaser 7750 Color Printer Repair - $249
MODEL: Tektronix Phaser 780 Color Printer Repair - $179
MODEL: Xerox Phaser 790 Color Printer Repair - $179
To further guaranty the quality of our services we accept COD payment (Cash On Delivery of service).Our technician will arrive at your location and repair your printer, get you printing again, then collect the payment.
We have technicians in:
Alabama, Arizona, Arkansas, California, Colorado, Connecticut, Delaware, Florida, Georgia, Idaho, Illinois, Indiana, Iowa, Kansas, Kentucky, Louisiana, Maine, Maryland, Massachusetts, Michigan, Minnesota, Mississippi, Missouri, Montana, Nebraska, Nevada, New Hampshire, New Jersey, New Mexico, New York, North Carolina, North Dakota, Ohio, Oklahoma, Oregon, Pennsylvania, Rhode Island, South, Carolina, South Dakota, Tennessee, Texas, Utah, Vermont, Virginia, Washington, West Virginia, Wisconsin, and Wyoming.
Itezen, Inc.
Tel. 516.776.7346
Mar 07, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 8200 Laser Printer Logo
139 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
