Question about Hunter Contemporary Classic 52" Ceiling Fan "Westwind White&Polished Brass"
Hunter ceiling fan leaks oil - Hunter Contemporary Classic 52" Ceiling Fan "Westwind White&Polished Brass"
  • 423 Answers
SOURCE: Check/add oil to a hunter ceiling fan
If you are asking for instructions on checking and possibly adding oil to a Hunter Original fan. Here are instructions:
Check oil level immediately after filling the reservoir. To check oil, bend an ordinary pipe cleaner into a 1/2" long hook and dip it into the oil reservoir.
If oil touches the end of the pipe cleaner, the fan has ample oil. If it does not touch, add SAE 10 non-detergent oil slowly until it touches the pipe cleaner.
-Hunter Original fans rarely/ never need oil unless they were relocated or tipped. ...Or if the fan was improperly installed.
-Hunter sells an oil refill / oil level check kit with good instructions. They also sell a relocation kit that includes the same kit plus all mounting hardware needed.
Good Luck!
Posted on May 05, 2009
  • 7 Answers
SOURCE: Hunter ceiling fan is stuck on high speed
If it has a chain, buy a light dimmer switch so it will not have 1 speed anymore. If it has a remote control, buy a new remote control like your old one. Try different numbers on remote control.
Posted on Jun 27, 2009
  • 5 Answers
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
Posted on Aug 13, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Posted on Aug 20, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
DO YOU HAVE TO OIL SOME HUNTER CEILING FAN
mine has been up for 40 years and never oiled it yet
Aug 29, 2014 | Hunter Concert Breeze New Bronze 52-Inch...
Can you oil older ceiling fan
You cannot oil the unit. The bearings are sealed.
Aug 29, 2014 | Hunter Dryers
DO SOME OLDER HUNTER CEILING FAN NEED TO BE OIL?
There are bearing in the fan but they are sealed. You could take it down and clean it real well. The bearings are hard to get to and the fan is not that expensive to replace.
Aug 29, 2014 | Hunter (25417) Ceiling Fan
Hunter origional leaking oil serial # 336023
Call Hunter to get RGA # to return for repair or find the nearest service center www.hunterfans.com 1-800-715-0393
Jun 14, 2014 | Hunter (25417) Ceiling Fan
A customer of mine has a very nice Hunter original ceiling fan that she never oiled and now the fan just hums and wont spin. Is it possible to repair after no oil damage is done?
Put some oil in and turn blades by hand to lubricate the bearings. If the motor is frozen, then you would have to take it to a service center or send back to Hunter for repair.
Apr 17, 2013 | Hunter 23852 Classic Original Ceiling Fan
Where can you buy 10w non detergent oil for use in a hunter original ceiling fan
I found Kendall 10w non-detergent oil on Amazon. Unfortunately you have to buy a case of 12 quarts for $50.
Jul 22, 2011 | Hunter (25417) Ceiling Fan
How do I oil my Hunter fan?
You don't. There's no place to oil ANY ceiling fan, not just the Hunter line. All ceiling fans use sealed ball bearings in the motors. They are lubricated for life. If you're experiencing a squealing noise, it would be best to take it down, pack if up and take it back where you bought it. No ceiling fan should squeal, let alone one as expensive as a Hunter.
Apr 22, 2011 | Hunter Dryers
Is sewing machine oil the same weight as ceiling fan oil?
No!
First, how old is this fan, and secondly is it exhibiting symptoms of low oil? If it is, just adding oil is not enough, you should change the oil in it, by removing the fan, placing paper towels (lots of them) around the part which the blades attach to and turn the fan over dumping the oil into the paper towels.
If it is not having problems and you just want to top it off, use either the Hunter fan oil, or a product called "Zoom Spout Oiler" Both are a 10wt Turbine oil. I have also used 5w20 engine oil in these fans with no ill effects, but I don't recommend it.
If you have any more concerns, don't hesitate to ask.
Here's the manual to your fan.
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41121.pdf
Sep 18, 2010 | Hunter 23852 Classic Original Ceiling Fan
I purchased the hunter outdoor fan about 3 years ago. All three of them are leaking oil. What is the problem?
Might be overfilled on oil. Oil should be only 1/2 " from the top of the reservoir. also check that the reservoir tank is on tight. Note (Left land treads).
Jun 26, 2010 | Hunter 23852 Classic Original Ceiling Fan
Good Luck!
Apr 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hunter Contemporary Classic 52" Ceiling Fan "Westwind White&Polished Brass" Logo
398 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
