Question about Toshiba Satellite A135-S2386 Notebook
Wont recognize new memory?
I recently upgraded the memory in my Satillite A135-2386.It runs Vista. Went from 512mb to 2gig but when I check memory in Systems Mant. is says there's only 894mb.Is it really only running on 894? I have been geting a message saying my memory is low. Any help?
  • 2 more comments
  • cheesapeekda Mar 10, 2009
    In BIOS it also shows 894mb of memory.
  • NorRellek Mar 27, 2009
    Having the same problem upgrading a friends A135. However, when I place both new 1GB modules, the system simply won't POST. Nothing happens. If I put in one of the 1GB modules, along with the 512K factory module, it will POST, but Windows only shows 1GB of RAM total. In the BIOS, it shows close to 1.5GB total *which it should). Makes me think that the memory modules I'm using are somehow not 100% compatible with the system. I'm going to return these and try another brand...these were PNY, btw. If I have any luck, I'll update here....
  • fossdc May 22, 2009
    I have the same problem. Toshiba A135-S3286. Added 1GB Kingston KTT533D2/1G PC4200 which is matched per Toshiba Direct. Only 894mb recognized in bios and Vista. Both slots tested and it does not make a difference : ( 512mb stick works, but is not adding to the 1GB. Wondering if V1.10 bios problem?
  • David Fitch
    David Fitch May 11, 2010
    When you look in the BIOS how much memory do you see?
  • 170 Answers
First try to reseat the memory, if it is still showing the same amount, then you may have a bad stick of memory, remove both and insert 1 stick into Dimm 1 slot and see if it still registers 894, then put the other in the same slot and see what it registers. Then try in the Dimm2 slot and see if you get a different reading Depending on the manufacturer, it may only show that amount since Windows shows memory different that the memory manufacturer.
Hope this helps.
Posted on Mar 10, 2009
Wont to upgrade graphic card my p.c has 2gig max ram in it wonts should i upgrade to to preform its best cheers mike
Depends on what kind of hardware you have
-Memory- 2 gb ram is "ok" if you use windows XP but if you have Vista or Windows 7 you should have a minimum of 4gb ram.
-Processor- if you have a Dual core processor you are ok, if you have a p4 or p3 you dont want to waste money on a new graphics card because it will not help you get better games, your processor and memory will slow you down instead.
So my advice is, if you have a OK computer, go ahead with buying a new graphics card if you computer is old and slow, DONT buy a new card! put your money on +2gb ram instead (cheap,and gives you more benefits) or maybe buy an "upgrade package" with new motherboard-memory-processor.
May 05, 2011 | Computers & Internet
Hi. I upgraded the memory on my Asus F5 from 512mb to 2gig. It has always given start up problems but now the charge light does not even come on when I charge and it does not start.
Hi
I would take the new memory out again put the 512 back in start up the computer hopefully and go to www,crucial.com and it will offer to scan your notebook for you and tell you what your computer is and i believe how much you can put into it then check what the new memory was and see if that helps
Nov 15, 2010 | ASUS F5R-AP038A Notebook
Acer Aspire Memory problem
check hardware compatability,vista is touchy,get xp
Sep 23, 2009 | Acer Aspire 5315 Notebook
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
Computer keeps rebooting
you either have a bad memory or bad memory slot!
good luck
please mark the post with a fixya
Feb 19, 2008 | Computers & Internet
Compaq Presario 5352 memory installation recognizing
be sure that the memory u got is compatible in your presario 5352. I tell you that adding 512mb to current 64 mb maybe a problem. you should remove the 64mb and replace it by 512mb and be sure that the new memory is compatible. want more information about your presario go to www.hp.com then search "compaq presario 5352"
melnavz
Dec 12, 2007 | Compaq Presario 5000 PC Desktop
More ram for my laptop
Never, NEVER buy a computer that is going to run Vista with less than 1Gig minimum!
2 Gigs of RAM is recommended for Vista.
To check on prices and the type check some online sites that sell memory
Most laptops have a removable door or hatch on the bottom where you can access the memory very easily. The modules easily clip in or out but never use force! (RTFM)
If you take it to someone, they'd probably charge $50 for labour, plus parts and the job takes 5 minutes.
Easily do it yourself, or find a teenager who's good with computers. Son, nephew, neighbour perhaps?
Before buying any new modules, check your laptop to see how many slots you have and what type of modules are in there now.
To upgrade to 2 Gig,  you will have to buy 2 new 1Gig modules, There's a 2Gig kit (1Gigx2) listed at one site for $80.
You would remove you current memory and install the 2 new 1Gig modules. Sell your 512 or make a keychain from it.
Oct 16, 2007 | Lenovo ThinkPad Z61m Notebook
Toshiba Satellite A135-S2386 Notebook Logo
446 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
