Question about Magic Chef Refrigerators
Our model is MCBR 415S. The top freezer acts as
Our model is MCBR 415S. The top freezer acts as if it is going through the defrost mode and the ice melts. The inside temp of the fridge registers 46 degrees on a thermometer. After about 3-4 hours, the freezer begins to freeze again. This has happened more than once. Please help. The unit is in a small room in a corner with a shelf above it. The fridge is full. Thanks in advance for your help.
  • Magic Chef Master
  • 3,361 Answers
You most likely have a bad thermostat control or a bad defrost timer.
Locate the defrost timer, probably inside the temp control panel.Defrost cycles should last 30 minutes then resume freezing.
Manually turn the timer control a 1/4 turn and see if it starts.
If so, replace the defrost control.
It could also be a bad temp control.
If the timer adjustment does not start the fridge. Tap the temp control. It may have stuck contacts.
Posted on Mar 10, 2009
I have a Kenmore top freezer. Every few days the freezer will get warm enough to cause the ice in the ice maker bucket to melt a little and then it will refreeze into a big block of ice when the...
Hi, It is sticking in the defrost mode...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Kenmore Top Freezer Refrigerator
Hi i have a magic chef model # mcbr 1010b it was working great unti i left the door ajar overnight and now it gets very cold in freezer @ 0 degreeze and refrig part stays around 50 and seems like it will...
Since you left door open I think the evaporator is frozen up .Just shut it off for a while and let everything defrost then turn it back on and you should be fine
Jan 05, 2018 | Magic Chef CTB1722 Top Freezer...
Freezer doesnt freeze and red light at top came on
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Freezers
Frosts up wont get cold MCBR1000S
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
My in-laws Amana ATB1832AR Top Freezer has stopped cooling. It was purchased 7/1/2005. Is there an inline fuse for the compressor that may have gone out?
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 13, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerator portion temperature has dropped to 65-70 degrees even on highest setting. This is an older model manufactured in 1992 with the freezer on the top. Serial # GG516729.
Aug 12, 2009 | Refrigerators
My new Refrigerator will go into defrost mode causing the frezzer to freez up
Um if its going into defrost mode then the freezer will get warmer not colder, its suppose to go into defrost mode to melt the ice on the evaporator, if the evap is getting blocked with ice then it is not defrosting, need a model number to help ya further
Jul 07, 2009 | Refrigerators
Magic Chef refridgerator with small built in freezer model#MCBR 980W. Defrosting instructions unclear; red button suppose to be pushed in for defrosting the small freezer, How is it suppose to actually...
I just defrosted my cooler and looked at the manual. It says that you should do it when the ice is only a 1/4 inch thick. Then it will do it without any effort. Well of course i waited till it was about 1 1/2 inches thick. The defrost button does help though. i pushed it and waited 3 hours and that loosened up the ice around the box. Then used an ice pick, flat head skrew driver, and a painters 5 in 1 tool. I cleaned the inside of the freezer fairly eaisly and let the rest of the defrost process clean the top and the sides of the box which i couldn't reach.
Jun 18, 2009 | Magic Chef Refrigerators
Auto defrost failure fo Majic Chef refriderator model MCBR 1000W
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Refrigerators
Refrigerators Logo
178 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
