Question about Technics SC-DV290 System
It wont read any disks and keeps coming up with DVD HO2 i've unplugged it for a while but it still comes up with the same message.
POSSIBLE solution
I had this problem a while ago comes up with that code then NO PLAY there are 5little discs inside that seperate the discs when theyre inserted these had come loose somehow I simply restacked them on the spindle, however they MUST go in a certain order or H02 will still appear, mine had numbers on them (but NOT consecutive) I just stacked em in ascending order. It worked great after that.
HOWEVER Ive just had the same problem again but the discs arent loose this time.
Posted on Apr 03, 2009
  • ENID Apr 26, 2011
    do i need to open the hifi to stack the cds
Wont read dvds and says that theres no disk inside when there is one inside
Hello i have three portable dvd players and after a while they all done the same thing they all say no disk when disk is inserted. I have try'd different disk but keeps coming up no disk can you help please advise
thank you
Jan 09, 2011 | Venturer PVS177W Portable DVD Player
The DVD player doesn't work. The service code HO2
I keep having h20 come up on my dvd play er what does that mean it want play
Jun 04, 2010 | Panasonic sa-ht800V Home Theater Audio...
My yamada dvd 7600xtv wont read any dvd discs at all the error message keeps coming up.
its ether youre laser dirty or broken try running a dvd lens cleaning disc in it
Nov 27, 2009 | Televison & Video
Unknow Disk - Please check disk again ERROR MESSAGE. Have tried previous burn disks the work no problems in the DVD player..... BUT disks I have burn as of today keep coming up with the above error...
The problem is you need to replace the laser assembly if the disc is spinning and not being read, or if the disc isnt spinning, you need to replace the mpeg printed circuit board attached to the laser assembly. Good Luck.
Jul 18, 2009 | GPX PDL805 Portable DVD Player
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
Dvd wont play ...each time you insert a DVD it shows DVD HO2...
I had the same Problem, player was only 13months old when the error HO2 appeared (typical huh?) anyway 2 years of this thing getting shifted from cupboard,wardrobe,attic, (did'n't want to throw it out cause it cost me £700), finally it came to fix it or bin it time. scoured the net to no avail, lost the rag and half dismantled it..then during all of this ( oops I'm going on a bit LOL)
you can hear a sound as though the disc is trying to be read, after 100's of attempts to get it to work, I finally noticed the disc had not changed position. (disc was not spinning) pointed to the Motor??
what I did to fix this was unplug from main's, remove top cover until you can see the top of the dvd disc, got hold of a pencil with a rubber on one end, plug back in, switch power on, and gently pushed top of disc ( clockwise ) and it kick started it off
that was over 3 years ago and the player is still going strong
I know its a bit rough, but nothing ventured nothing gained ;)
Feb 17, 2009 | Technics SC-DV290 System
Error message HO2 shows on vhs display
the player begins to read dvd. display will read 00---READ and it repeats this process a few times and the error then is displayed next.
Jul 10, 2008 | Panasonic Televison & Video
Won't read dvd or cd
Hi , visit www.compuvest.com you can find dvd-rw driver on sale.
May 14, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Error Code:DVD HO2
try to clean it first bring cleaner cd from radio shack. put your cleaning disk in and let it run-remove cleaning disk and put your disk and try,
Nov 03, 2007 | Panasonic SC-HT75 System
Display message HO2.
Hello, though I think it is a temporary solution you can try this:http://www0.dealtime.com/xPR-Panasonic-DVD-S35S~RD-228464823940 Best regards, Arpi
Apr 27, 2007 | Panasonic DVD-S35S DVD Player
Technics SC-DV290 System Logo
259 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
