Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
Above is the verge with a slip clutch.
Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
