Question about Citrix SonicWALL Global Management System Entry Edition (01-SSC-3350) for PC
SonicWall says to install McAfee even though it is already installed. Current installation not recognized by SonicWall.
Mcafee installation retail card
Prior to installing McAfee, were you already running another anti-virus, even an expired version? If so, that is your likely culprit. To rectify this situation do the following: Power computer on and press f8 to open safe mode. On some computer's, one must time this just right; so, if you do not enter safe mode on the first try, then repeat and quickly press f8 until you do. Once you are in safe mode, scroll down and click on safe mode with networking so you will have internet access during this process. Now, go to control panel and then to remove programs. Uninstall both the McAfee and any other anti-virus programs listed. Save all changes and exit safe mode and turn computer off for one full minute. Your computer should now be working again and you should be able to reinstall the McAfee and with no impact upon the performance of your computer.
Aug 27, 2014 | Computers & Internet
I want to re-enter my security key no as i had to replace my laptop
If you replace your laptop, you will need to also replace the McAfee software as each computer is recognized separately with McAfee products. Go to the McAfee site, log in, and download your purchased product. Sometimes, you will also need to deactivate your Firewall before installing the new product as it will interfere with the installation. Your purchased products and keys will show up in your account with McAfee. Hope this helps.
Jul 12, 2014 | Mcafee Total Protection: Windows
Macaffee antivirous is not working though it is valid upto May 2011
Try to repair the installation.
START > Control Panel > Add or Remove Programs
highlight the McAfee program - click on the "change/remove" button, and if there's an option
provided to repair the installation, select it.
In the absence of that option (every package is responsible to provide its own options), then
run the McAfee software from the desktop shortcut (icon), or
START > All Programs > McAfee
then find and run an option within this to "update" or "repair" your current McAfee installation.
Viruses will often attempt to damage anti-virus software installations or block access to
Symantec or McAfee web sites, so repairing anti-virus installations is commonly needed.
Feb 21, 2011 | Computers & Internet
It won't install
# Download McAfee Antivirus:
Click here if you are using Windows 7, Windows Vista, or Windows XP .
# Click on Run.
# When the download is complete, the installer will begin preparing itself.
# Begin the installation by clicking "Next".
# Select the appropriate License Expiry Type (in the drop down menu in the upper left of the window). Then select the button for "I accept the terms..." and click OK.
# If you already have McAfee Antivirus installed, you may see this screen. Just # click OK and the installer wizard will import your old settings into the new version of McAfee.
# For Setup, type Next
# The Wizard will now begin installing the files. It may pause the installation process and ask you to end particular applications so that it can safely continue the installation.
After a successful installation, McAfee will ask if you want to update the virus definitions and run a scan; you should do both.
Once installation is complete, McAfee will automatically update the virus definitions. Once the updates are finished click Close.
Install McAfee
Feb 09, 2011 | Mcafee RETAIL BOXED PRODU MTP08EMB3RUA...
Mcafee anti-virus file sys filter driver removal
try here... this may have what you need. its a removal tool
May 27, 2009 | Kaspersky Labs Kaspersky Anti-Virus 2009...
Trying to uninstall spysweeper to install mcafee
its ok now folks . i got it sorted myself . mcafee must have some firewalls that wont allow even traces of another programme through. i installed f-secure instead with no problems whatsoever . thanks for your time.
Dec 08, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Not able to see HP C6180 on SonicWall TZ 180
Not sure if you've done this already or not, but I would suggest installing the printer manually as a local printer, and create a TCP/IP port that points at the IP of the Printer. Rudimentary way to go, but should help.
Jan 16, 2008 | SonicWALL Total Secure 25 VPN Gateway, WL...
Citrix SonicWALL Global Management System Entry Edition (01-SSC-3350) for PC Logo
133 people viewed this question
Top Citrix Computers & Internet Experts
xxxxxx xxx
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
