Question about Gateway Computers & Internet
How do i find out if a gateway NX560XL laptop has a GPU cooling fan?
  • 170 Answers
It looks like the heat sink covers both the CPU and the GPU and a single fan cools this. Hope this helps....
Posted on Mar 10, 2009
Gateway mt3422 black screen
GPU needs to be re-balled. It is because cooling pad on GPU is not efficient and GPU overheats, melting ball contacts. There are some re-balling services on ebay that will reball GPU and install a more efficient cooling contact on the GPU.
Feb 16, 2014 | Gateway MT3705 Notebook
GPU cooling problem
Try reinstalling the heat sink and putty on GPU. Make sure heat sink is fitting correctly. If the only thing you did was upgrade the fans and redo the putty, then your heat sink didn't seat properly.
Nov 01, 2013 | Acer Extensa Computers & Internet
Gateway P-7809u PC Notebook: Temperature High
Try also to elevate the computer base to keep ventilation good; perhaps invest in a laptop cooler. You are not going to be able to change the fan settings on this particular computer.
Sep 19, 2012 | Gateway P-7809u PC Notebook
I am trying to reload my computer and about 10 minutes into the recovery process it shuts down. I have replace the fan, the hard drive, the battery, the keyboard, the power cord, and memory. Why does it...
90% of the time shutdowns are related to heat problems in the CPU or GPU (Video). The laptop will shutdown to avoid damage. Verify the cooling fins on your heat sink are not clogged as an external cooling fan will not correct this problem. If the fan is running test with a strip of tissue or candle and verify you have air circulation.
If you are certain temperature is not an issue, the next step is to insure you are not having hardware related errors.
You should always start with a completely charged battery and also have your adapter plugged connected.
Finally be sure you are using the original recovery software (incorrect licensing will abort the recovery process).
Feb 17, 2011 | Gateway MX6027 Notebook
There is no video on my gateway 6520gz tried connecting to the monitor still nothing can hear the fan running and power light is on
This sounds like a common GPU issue that's affecting alot of laptop users. Your options are:
1. (Not recommanded but it may work) Take out the hard drive and battery then turn on the laptop . while still on, wrap the botton portion of the laptop with a towel until it gets really hot. This is to overheat the laptop for the GPU to stick back to the motherboard. Don't leave the laptop unattented and it's also a fire hazard. Perform this at your own risk.
2. Remove the motherboard and reflow the GPU with a heatgun.
3. Replace the motherboard.
Feb 11, 2011 | Gateway 6520GZ Notebook
I have Gateway NX560XL Laptop. Work fine. Next time tried to use it , it comes on fans run and all, but screen Never comes on. Has harddrive gone bad?? Do i need a new laptop??? I have tried every...
Your screen may have gone out - try hooking up an external monitor with a VGA input. Connect it to the VGA output of the laptop. If you get a display, your screen inverter or backlight has gone out. If the hard drive light on the control panel is flashing then the harddrive is likely ok.
Oct 28, 2010 | Gateway NX560XL PC Notebook
My gateway MA1 laptop running win xp has cooling problems
Contact GATEWAY, and get them to fix your laptop.
The fan is designed to run at "full-speed" when you first turn it on, and then there are temperature sensors that slow the fan down, to minimize noise, while the computer is "cool" enough that the fan does not need to run. The sensor is malfunctioning, and is not turning-on (or turning-up) the fan when the computer gets "warm".
Jul 17, 2010 | Gateway Computers & Internet
Gateway MX6453 overheated and won't power-up.
Yes I think it can be repaired.
Can I tell you what is wrong with the laptop, without physically looking at it myself?
No.
You need to take it to a pro for a diagnoses.
Will tell you that when a Processor becomes too hot it turns off. (BIOS program turns it off)
This is a Fail safe feature built in that keeps the processor from burning up.
How did the laptop become too hot?
Usually falls within three categories, or a combination of them.
1.The laptop Cooling System hasn't been cleaned on a regular basis.
Cooling System:
A) Air Intake Duct,
B) Cooling Fan,
C) CPU Cooling Tube/Heatsink assembly,
D) GPU Heatsink assembly,
E) and the filter located in the output port, of the Cooling Fan's housing.
A, and B above can be cleaned by the user/owner, with a can of compressed air for computers, with the proper procedure.
[AC adapter {Charger} removed if plugged in, and Battery removed FIRST, for One. Compressed air from can must be applied in a correct procedure or damage to the Cooling Fan's bearings may result, for Two. There is more]
C, D, and E, require partial to complete disassembly of the laptop, and advise approached by a professional.
(CPU - Central Processing Unit, or Processor for short.
GPU - Graphics Processing Unit, or graphics chip for short.
Heatsink - resembles a radiator with it's finned setup. Like a radiator, the heatsink is designed to absorb heat, with air flowing over the fins of the Heatsink to dissipate the heat)
2.The laptop user continually blocks the Air Intake Duct.
A. With their clothes, (Sitting on lap),
B.Bed covers, (Sitting the laptop directly on the bed while using it)
C.Sit the laptop directly on a carpeted surface while operating it.
3.Physical Failures:
A.The Cooling Fan bearings are bad. The Cooling Fan no longer operates, or does so at a reduced rate.
B.The Thermal Paste has dried up in-between the CPU, and it's Heatsink. Lack of heat transference from the top of the CPU case, (Processor), to the Heatsink is minimal to zero.
C.The Cooling System for laptops is inadequate to start with.
All the hardware components are compacted into one tiny box. One small fan draws air through the laptop, with small inadequate heatsinks to dissipate the heat.
Add to this that some laptop designers fail to meet the mark, with their cooling system designs.
The laptop may need additional cooling, such as provided with a cooling pad.
The Gateway MX6453 Notebook PC,
uses an AMD Turion 64 X2 processor. [TL-52]
(TL-52. Operates at a maximum of 1.6GHz frequency rate. {1600MHz}
2x - 512MB L2 cache. 800Mhz Front Side Bus)
http://en.wikipedia.org/wiki/List_of_AMD_Turion_microprocessors#Dual-Core_Mobile_processors
An AMD processor without cooling. will burn up in a New York minute!
This may be the problem now with your laptop.
Perhaps the laptop was used without the Cooling Fan operating, (Or operating at a less than capacity), and the laptop shut off. (Processor turned off)
Laptop was started again, and again, eventually to never start again.
Could be now that the AMD processor is fried.
If so, the Thermal Paste will need to be properly cleaned off of the CPU Heatsink assembly, and the proper amount of new thermal paste applied, with the installation of a known, good AMD TL-52 processor.
This is all I can offer from your brief diagnoses.
As for the SATA 2.5 inch harddrive you have in the laptop, just buy an external enclosure.
A decent SATA 2.5 inch external enclosure, is around $20.
(The width of the harddrive case in inches.
2 and a half inches, {2.5} for a laptop harddrive.
3 and a half inches, {3.5} for a desktop harddrive)
Remove the harddrive from the laptop, install it into the external enclosure, (Instructions provided with the enclosure), and plug it into any laptop, or desktop computer.
The external enclosure has a USB cable coming from it, that you plug into any USB port on a computer.
(You essentially now have an External Harddrive)
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2783
I do not recommend buying another Gateway MX-6453 laptop, and trying to install your harddrive you have now.
Why?
Because when Windows is installed on a computer, it assigns hash values to certain major hardware components, inside the computer.
You may think of these hash values as serial numbers. (They aren't, as no personal information of the computer owner is recorded)
Hardware components such as,
1) Harddrive
2) Motherboard. Or to be more specific, BIOS program, and version.
3) Processor
4) Graphics (GPU)
,and other hardware may be recorded.
You may be lucky, and Windows will want to be Activated again.
You may not.
Dec 17, 2009 | Gateway MX6453 Notebook
Can i upgrade the cpu in a nx560xl laptop.
No.. It cannot be done..if you need more computing power buy a new unit..
Sep 11, 2009 | Gateway NX560XL PC Notebook
Gateway laptop fan problems
IF you trust yourself, take apart the laptop and apply a thin coat of thermal paste to the processor, and put it abck together. This should help.
Dec 18, 2008 | Gateway (8008625) Cooling Fan, Heatsink...
Computers & Internet Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
