Question about Nikon COOLPIX P5100 Digital Camera
I have a Nikon Coolpix P5100. I use it to photograph my paintings
Results are quite poor. I tried several settings, I take the pictures with natural light. What setting do you recomend.
Before I had a Sony and had no problem. Please advise. I am dying to get something else, probably a Sony but I am strap for money.
    Problem Solver:
  • 10 Answers
There could be a number of reasons.
First, Have you tried it in P mode and are the results the same? Then, have you tried taking images in M mode and set the exposure yourself? Do you have the same result?
Second, If you are shooting in P or normal mode the Exposure compensation might have been incorrectly set. On the Navigation control to the right of the OK button is where you can set Exposure compensation. Press it there and you will see some information appear at the bottom and left side of your LCD. The bar on the left will consist of a series of white graduations with the centre one yellow. If you have yellow bars above the centre one then your image will appear lighter as if over exposed while if you have yellow bars that extend below the centre one your image will appear darker as if under exposed. To reset it use the navigation control to scroll either up or down then press OK once it is where you need it.
Last, if that doesn't work, try checking the ISO. With the camera on in P mode press and hold the Fn button at the top left of the LCD. Scroll to Auto using the command dial next to the shutter release and release the button. If it was already on auto you could try setting it on 2000 and seeing what the result are like then. Don't leave it on 2000 as you will get grainy images but you should get lighter shots as it will allow the camera to cope with poor light conditions. Reset the ISO to Auto and if it still isn't working properly you will probably need to get it serviced.
Posted on Feb 09, 2010
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
My fujifilm jx camera won't take good pictures in poor sunlight inside areas
I recomend that you read very well your owner manual.take some maintenance, clean the lens, lcd, change DIGITAL batt.etc. follow the instructions m.
This can have valious information about how to get good quality picture.
Can be a problem from your a) camera vs your person.
Do it.
God bless you
Sep 17, 2012 | Cameras
How to take a good picture in bad lightning
You can find the manual here. They have some suggestions for shooting in low light:
  • Set scene to "NATURAL LIGHT" Capture natural light indoors, under low light, or where the fl ash can not be used.
  • or set Scene t "PARTY" Capture indoor background lighting under low-light conditions.
Use a tripod if available, or brace the camera against a wall, table, or other fixed object when taking pictures to reduce blurriness.
If you don't have an object to brace the camera against, use these techniques to reduce camera shake. Press the camera button instead of jabbing at it.
Search the internet for "low light photography" for more tips. The PARTY and NATURAL LIGHT settings on your camera should boost the ISO on your camera.
Do some test shots before hand in low light situations to see what works best.
Feb 11, 2012 | FUJIFILM FinePix S2950 / S2990 Digital...
THE PICTURES ARE WAVY.
Try messing around with the lighting options in the camera, since certain lighting settings give different results than expected, for example, setting the camera for low-light pictures in daylight.
Setting it for automatic should solve the problem
Jul 26, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
The night setting results in blurry pictures
The grain is from underxexposure and the blur is from hand shake caused by low shutter speed. Try using a tripod. Also, change from auto settings and shoot in manual mode with a high ISO and low aperture setting. Good luck!
Jul 15, 2009 | Nikon COOLPIX S200 Digital Camera
I have a Sony Trintron KV-PG21P40. When I'm
Since the set recovers under some conditions, I would first look for poor solder connections. With a set of your vintage, it is common for some of the connections to become faulty. If you can solder, resolder any connections on the board that appear grainy or have rings. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
Keep us posted on your progres.
Dan
Mar 09, 2009 | Sony Televison & Video
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Tv will shut off while viewing. standby light flashes.
The problem with your Sony. This is a common problem with these Sony sets.
1. How many times does the light blink? Is it consistent and continuous?
2. Does anything happen to the picture itself, or does the set just turn off?
Answer that and I can help you.
Nov 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Bright pictures
It seams under warranty, ask to Sony, they will replace it with new one.
May 29, 2008 | Sony Cybershot S650 Digital Camera
Not happy with my CD300
The problem is in your ISO. The camera has a terrible noise problem at anything over 100 ISO. I set my camera to 100 even when shooting in auto, and never use any other ISO setting - the results are just not worth it. Hang in there. The camera is awesome and you will make friends with it. The settings are really not that complicated once you get used to them. Just decrease your shutter speed and increase your aperature (lowest number) when in low light conditions and watch the LCD until it looks good (you might have to half press the shutter to get a preview), until you get a bettter grasp of what those adjustments are doing for you. Good luck, Cindy
Sep 12, 2005 | Sony Mavica MVC-CD300 Digital Camera
Nikon COOLPIX P5100 Digital Camera Logo
88 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
