Question about Nokia 7610
MY NOKIA 7610 KEYPAD CONNECTORS TWO PRINT BROKEN WILL YOU SOLVE THIS PROBLEM?
Just use jumper between key plate and keypad connector..
Posted on Mar 16, 2009
Nokia supernova 7610 phone screen has gone black
Your mobile screen connector point must be having loose or a faulty screen. Best it will be to take it to the servicing center.
Thank you for asking on fixya.com
Mar 20, 2013 | Nokia 7610 Supernova Cell Phone
Where is the keypad ic
This is where the keypad IC of nokia 7610 is located.
Good Day..
Sep 04, 2011 | Nokia 7610
I'm using 7610 supernova, and last night i switched it On but the screen display is white (with the option of Inbox, Menu, Calculator), it doesn't show the signals nor getting any command from keypad. I...
this problem come from your phone that did not recognized your sim card, try insert your sim card to anohter phone, if at another phone it recognized the problem come from your nokia 7610 supernova sim card slot section, change sim card slot with new one, this will solve your problem
i hope this helpful
thank you for using fixya
Jan 29, 2011 | Nokia 7610
Nokia 7610 keys 3,5 and * not working. pls help. thanks....
i think this is a dusting problem so open your cover & clean your keypad if problem not solve then
change your keypad or check their hardware..
Jan 23, 2011 | Nokia 7610
My nokia 7610 light on the keypad no light on the screen
how to use a jumper? my nokia 7610 has a keypad problem, it had been repaired once, but it came back.. then later after i had just checked it without doing anything on it, it happened that the light went low and there's no more display on the screen..
kindly help me :( if there is a solution for this before i'll bring it to a cellphone repair shop.. so i can have lesser expenses..
thanks in advance..
Nov 04, 2010 | Nokia 7610
Nokia 7610 display connector tracks
display connector print
Nov 02, 2010 | Nokia 7610
The navigation keys of nokia supernova 7610 are not working.. and its memory card has also locked up itself ... plz help.....
open your phone cashing than also 4 screws under LCD.pick key pad,use( - )screw or cutter eyes.clean keypad connector use pencils erraser (it safety).also open white plastic on key pad clean it up too. its often happen.Good luck.
Apr 14, 2010 | Nokia 7610 Supernova Cell Phone
Nokia 7610 charging
First insure that is your charger ok? you can try it by using other charger. if your charger is ok then check your charging connector.but if the section is ok in your mobile charger section which name "k" is bad. then you need to change that. thanks
Feb 25, 2010 | Nokia 7610
Nokia 7610 it's not switch on
that problem is called no power, there are many reason why it is not on, first is the battery terminal or connector, check also the POWER IC, Signal IC, Power Amp, and lastly the CPU, refer it to the technician if you dont know how to open your fon to the hardware system
Apr 07, 2009 | Nokia Cell Phones
My Nokia 7610 Keypad Problem
my 7610 keys 2 , 5, 8 and * are not working. kindly give me any solution.
Jan 22, 2007 | Nokia 7610 Handheld
Nokia 7610 Logo
233 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
