Question about Acer Aspire 1690 Notebook
Not booting my system is hanging at the time of booting.i checked my hdd by extenal,it is detecting
Desktop hangs at "verifying dmi pool data"
Hello here is the MSI homepage:
http://www.msi.com/product/mb/P4M900M2-L.html#/?div=Driver&os=Win7%2064
Here is an overwiev of the problem:
http://www.computerhope.com/issues/ch000474.htm
Try to go into your BIOS and make sure that the harddrive with the Windows installed is correctly set as the primary boot device. Choose the HDD as primary boot device, followed by CD-ROM/Floppy. Also make sure that the HDD is set to auto-detect within the BIOS utility.
If you have any discs or diskettes in the CD-ROM or floppy drive(s) then please remove these and try and boot up again, this is to make sure the system is not trying to boot from another device.
Make sure ALL cables are 100% connected to the system and are not loose at any scale. If any of the above does not work then try and reset the CMOS using the CMOS jumper.
If still nothing above fixes the issue then you may have to replace/fix the master boot record on the harddrive, or renew the harddrive as this may be the cause of the problem.
Good luck
Apr 08, 2013 | MSI Bios Chip:P4m900m2-l Ms-7255
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
I have a acer aspire 3680 and it want boot up operating system not found. Can you please help me.
1. Go to BIOS setup at the time of booting by pressing F1 or F2 or Del Key. Select the first boot device as HDD. Also check whether HDD has been detected. Save and restart the system. (If not detected then check it with technician.)
2. If still not booting, if you don't have any data required on the HDD then try using recovery CD and boot through it to restore your OS to the manufacturers default.
3. If you dont have much idea about these process better handle take help of service engineer.
Sep 11, 2010 | Acer Aspire 3680 Laptop
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
Unable to login in my computer
try setting your bios to defaults when you get in that bios screen.make sure to save it and then exit.you may also need to reinstall windows os .vista or xp etc.
Mar 04, 2009 | HP Hewlett Packard Smart Buy- dc5750...
PC Hardware Troubleshoot, works slowly,IDE not detected sometimes
try go to this website download Download SeaTools for DOS now!
http://www.seagate.com/www/en-us/support/downloads/seatools/
and run diagnostic to hdd but remember stand by floopy disk to create diagnostic disk.IF this diagnostic disk check said no error so you hdd is ok.try put the ram to different slot.you pc may be is RAM or motherboard faulty
Dec 21, 2008 | Computers & Internet
Virous in removeble harddisk
try to boot to safe mode, and see if it is detected. If it is detected in safe mode. Uninstall and reinstall any drivers that came with your external hdd. If still no go, reinstall windows. If after reinstalling windows, still not detected, replace external hdd.
Feb 16, 2008 | Microsoft Windows XP Home Edition
CMOS auto detection of samsung SP0411N HDD stops and hangs
Hi download this program its seagates diagnostic tool, put in floppy disk and run program to make a boot disk, restart pc, and let it boot off the floppy disk and it will test the drive for you... http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD All the best john
Feb 16, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Acer Aspire 1690 Notebook Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
