My 6 month old Sony CD rom has had problems since the time i got it. I frequently get read errors on perfectly good cd's. The performance of the reader is crappy too.
According to my Ms Sysinfo it's transfer rate is 2560KB/s(after many tries) and according to sony the transfer rate is supposed to be 7500KB/s.
When I burn cd's at 10x the cd rom can't handle it, forcing me to copy everything to the HDD first.
Has anyone else noticed this poor performance on this reader.? What should i try and replace it with?
I have exactly the same problems with my Sony CDU-4811.
My observation is that when CDU4811 is spinning at high speeds and then encounters read difficulty, it makes *no attempt* to spin down to a lower speed and retry - it just bombs out with a fatal read error. This bizarre behaviour of the Sony CDU-4811 mades it near useless.
That's not the way CDROM drives are supposed to work - they should spin down to a speed where the *can* read the cdrom.
I found the problem most severe with CD-R disks where reading is likely to produce more errors at high speed than factory-pressed CD's.
My guess is that the CDU-4811 has buggy firmware (I have PY09) but according Stephen (below) even PY0A doesn't fix things.
I have just send a report of the problem to sony.storagesupport.com. I wonder if I'll get any response.
Ed
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Crappy Sony CD ROM (CDU4811):
Solution #3
posted on Aug 02, 2007
LiZzIe - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
I'm having the same problem on a PIII 800. To get consistent results, and 8x writing on my writer I have to copy to disk first. I think that having the reader and writer as master & slave respectively on the same IDE controller might have something to do with it.
Anyway, I could handle this ok, but the 48x CDU4811 turns out to be pretty useless for anything but playing audio CD's.
That is, even when burning a CD isn't involved, I get read errors from the 4811, both when installing from that drive, or copying its contents to hard drive. I've got to use the CDR drive for all that stuff.
I found a site that had a firmware update, but the latest firmware update they have is PY09. The version I've got is PY0A. Assuming the last two digits are hex, I've got the later one already.
Any clues?
Stephen Walter
Sent via Deja.com #
Solution #4
Peter1 - usenet poster
... try turning on DMA
This would the best way to do it CD to CD will more than likely cause buffer underruns if they are not copied to a temp file first "the Hard Drive" 33Mbs transfer for a average HD against 2.7 mbs or even 7.5 Mbs for a cdrom Which would you pick to read from . Lets see this is a rough example 10 X burn x "1200kbs = 1.2meg a sec" = 12Mbs Hmmm thats a short fall of 4.5meg = Coaster buffer underun Simply put you are burning the data faster than it can be read do your burns from the HD it rakes a little longer but you dont make coasters and determin you maximum speed its usually in you burner software in prefs
Maybe a faster cpu an new motherboard if you only have a 200 mhz or less you give no info on your config I had 200MHZ myself noway could I get it to burn over 4X
anyway how this helps Regards MC
