Webcam wont work in msn messenger
Im trying to use my webcam in msn messenger but wen go to use it, it comes up with " We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again."
It was working fine the last time i used it. ive tryed everything i know to fix it but i cant please help??
  • 2 more comments
  • m_lodding Mar 11, 2009
    I uninstalled the camera driver and msn, did a virus check of the computer with Mcafee and there was nothing found and i have reinstalled both and it is still saying the same thing....
    Just so you know im using Windows Vista and the only things that are running down the bottom are msn, my internet connection, mcafee, Cd/DVD Drive Acoustic Silencer, then volume??
    Tryed but didnt same thing coming up..
  • 19,396 Answers
Try the following:
1)Open messenger and go to the tools menu, audio and video setup
2)click next button
3)select type of speakers or headset if you have any
4)select microphone
5)select webcam
6)click finish
Posted on Mar 11, 2009
    Novelist:
  • 149 Answers
Try restarting the computer with the camera plugged in to the computer. Also you may want to Uninstall the drivers reboot the system, re-install the drivers and check to see if that works.
Please rate this solution
    Scholar:
  • 164 Answers
Hi;
Have you tried plugging the Webcam into another USB socket and see if that comes up with the same error.
If you have re-installed then did you restart the PC?
If you do restart you will find it should work.
I hope this helps,
Thanks.
  • mohammed naseer
    mohammed naseer Mar 11, 2009
    Sometimes there are issue's due to Mcaffee running.. Here is what Mcaffee suggests:
    http://service.mcafee.com/faqdocument.as...
    Due to changes in the new version of Live Messenger 2009 (v14), you may be unable to use the webcam and video conferencing features when SiteAdvisor is installed.
    McAfee is aware of this issue, and is working toward a resolution.
    Solution
    As a workaround, McAfee recommends configuring SiteAdvisor to stop monitoring Live Messenger.
    Navigate to the following folder:
    Windows XP/2000/Vista (32-bit): C:\Program Files\McAfee\SiteAdvisor
    Windows Vista (64-bit): C:\Program Files (x86)\McAfee\SiteAdvisor
    Right-click on the file sasets.ini and choose Open With, then select Notepad.
    Locate the section titled [msnmsgr.exe].
    Change Enabled=1 to Enabled=0.
    Click File and select Save.
    Close sasets.ini and restart your computer for changes to take effect.
    Please let me know if that works.
    Thanks.
  • 10,515 Answers
Http://service.mcafee.com/faqdocument.aspx?id=TS100601
Unless
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps
  • 2 more comments
  • taran_2005
    taran_2005 Mar 11, 2009
    Have you tried my solution. There is a link of the press conference as well.........DO read that.
    I am waiting for the response.
    Thanks.
  • taran_2005
    Make sure site advisory if any must be uninstalled...
  • taran_2005
    you can also try this
    you close MSN
    than go to
    start
    control panel
    add&remove programs
    ‘windows live essentials’(if using WLM 2009)
    ‘windows live messenger’(if using WLM 8.5)
    click on 'remove'
    and then on 'repair'
    wait til the wizard finishes
    sign in again
  • taran_2005
    tell me if the above 2 steps would solve your issue. Unless we would do some more troubleshooting :)
  • 98 Answers
Hello what other programs use your cam?close all programs.look on your tool bar and make sure all progeams are closed. that might use the web cam.ok now plug in the webcam.then start msn.
  • 583 Answers
Connect the camera in a different usb port.many a times this will help solve this problem without doing anything else.
  • 356 Answers
Try to stop any other program that may be using the camera.
In the Task Bar at the bottom of your windows screen you will see several small icons, these represent programs currently running.
If you have AIM(AOL), Google or any messenger or webcam program, place your cursor on the icon and Right click, a small menu should appear, use the Stop option to quit the program.
Let me know what you find and which programs you have running.
Lone99star
Posted on Mar 10, 2009
    Genius:
  • 1,913 Answers
Your computer is virus infected.u have to remove your camera driver form computer then again reinstall it.
also scan your computer with good antivirus.
In im i cant invite to see my cam why
Probably because you are in a different program to your contact
Cross chatting does not support webcams
If you are in Yahoo Messenger for example and your contact is in Yahoo Mail or Yahoo webmessenger or MSN the webcam feature is not available the option may be greyed out or missing.
You both have to be in Yahoo Messenger or MSN
Oct 29, 2009 | Radio Shack VGA PC Camera Webcam
How to get labtec webcam to work on msn live?
this is the error msn i get when iam trying to use my camera in msn messenger on all other i can use ? whats the reason ?
Oct 09, 2009 | Xirlink Promax Webcam
My Microsoft LifeCam Wont detect on MSN!
Once you have your webcam working outside of MSN you can then proceed to configure it to the MSN software
Its good practice to disconnect / re-connect the camera to the USB port before you start. Sometimes the camera remains hooked up to a previous program and the MSN software cannot find it.
Connect webcam
Open MSN - Windows Live Messenger
Click ( > ) Open Menu > Tools > Audio & video set-up - run through Audio > Next - set your camera default - assess webcam quality and use the Webcam Settings to make any refinements > Finish
Aug 22, 2009 | Microsoft LifeCam VX-3000 Web Camera
Wont work with windows live messenger 2009
Try going into the 'audio adn video' options in MSN and tuning the camera and audio.. ie testing it out. You have to choose the camera n stuff.. so you may not have it as default..
Jun 01, 2009 | Microsoft LifeCam VX-1000 Webcam
Webcam works on msn but the picture is black and fuzzy
go to Logitech's website...click on your product model and from there you can download the latest drivers. Make sure to note that most device drivers for Vista 64 bit systems are different from 32 bit.
Hope this helps.
May 04, 2009 | Logitech QuickCam Messenger Web Camera
When I try to talk to some one with the webcam on MSN Messenger I can see them but they can't see me. My webcam is just picking me up instead and not broadcasting to them.
try a different IM like yahoo messenger ..if it works...and it broadcasting ..it means that its something wrong with your msn messenger and need to reinstall it
Apr 09, 2009 | Logitech QuickCam Pro 5000 Webcam
Hi...ive got a Lifecam VX-3000 that i installed and did use with MSN messenger, it've been workin for about a year now with no problem , bt since a couple days ago it stopped working for no reason, and...
with this version its cos its not a win32 app, im having the same problem and only just found a site to update it with new software. microsoft dl page was not working properly for me. try software for lifecam _1_4 should help you
Feb 27, 2009 | Microsoft LifeCam VX-3000 Web Camera
Philips spc 700nc web cam
First of all, have you verified you are using latest version of MSN messenger. If so and the problem still exists, give one of the other instant messengers a try, say like YM or AIM or any number of others.
What exactly do you mean by ' seems to work '?? Can you see yourself in the cam using whatever software other then MSN that you may have on your computer.
Feb 20, 2008 | Philips SPC700NC Webcam
Wont work on Msn
Here is a tutorial follow it and ya should be all good. http://www.microsoft.com/windowsxp/using/windowsmessenger/ballew_video.mspx
Aug 18, 2007 | GE EasyCam Webcam
Computers & Internet Logo
29 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
