Question about Polaroid TDX-02610B LCD TV
TDX02611C WAS ON AND OUT OF THE BLUE AND SORT OF SNAPPED AND WENT OFF. I CHECKED ALL ELECTRICAL SUPPLY LINES, BUT ALL IS WELL EXCEPT FOR THE UNIT. UNITR WAS PURCHASED 12-15-08 WALMART. I CANNOT GET IT TO TURN BACK ON NOW, RED LIGHT THAT PRECEDES BLUE LIGHT IS NOT ON. PLEASE ADVISE. THANK YOU, DON
  • xkrazyangelx May 24, 2009
    i am haveing the same problem as stock and i cant get no one a polaroid to answer a damn phone i know if i cant get this fix cause it is less that a year old i will never purchase nothing made by Polaroid.
I had the same problem and I literally had to wait 2 hours on the phone to get a Polaroid rep...And you need to do this in order to get an "RA number" in order for you to return the product....
They actually did send the TV back and I was surprised to see that they sent it back within 2 weeks!
The TV turns on now, however, I'm just having a problem setting up the remote to program the TV and the codes aren't working...that's why I'm on this website now to look for help.
Good Luck to all of you that have this problem.
And I hope we all learn a lesson to NEVER EVER BUY THEIR PRODUCT AGAIN
Posted on Jul 18, 2009
  • george xenakis Sep 15, 2010
    I had this problem and replacing a shorted "large" Diode marked D10 on the power suplly board fixed it. The part cross references to NTE5319, only costs .50 cents.
Troubleshoot SAMSUNG ICEMAKER FOR REFRIGERATOR AND FREEZER UNIT BELOW NEITHER IS FILLING WITH WATER?
do u have a K i N K in hose somewhere do you have water in the line they have that little blue pump make sure you are getting power to it and have a ground ,
Dec 02, 2014 | Samsung RF265AA Bottom Freezer French Door...
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
JVC LT32DA30J NO POWER, NO BLUE LIGHT
Sounds like a warranty job - pop noises are electrical shorts - Possibly the power supply unit.
Jan 31, 2013 | Televison & Video
I bought an electric power washer from Costco
Look for the your washer on ebay. Often you find the units and on same page it is very common to find parts for the unit! And on ebay you can shop for and get all sorts of electronic and plumbing adapters that are virtually impossible to get - they may come from China and take a few weeks to get to you but they are inexpensive and they work and are guaranteed! eBayeBay
Sep 20, 2017 | Electronics - Others
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
What is brown out
Brown-out .... What is it? Brown-out is a condition of lower than normal power line voltage being supplied by your local utility or generating equipment. This condition may be short term (minutes to hours) or long term (1/2 day or more). A power line voltage reduction of 8 - 12% is usually considered a Brown-out.
What causes Brown-outs? Electric utilities (your local, lovable Power Company) may occassionally reduce line voltage to Brown-out levels in an effort to adequately manage power generation and distribution during periods of heavy usage. Very hot days, when most air conditioning and refrigeration equipment would be operating almost continuously, is an example of such a situation.
Even without utility intervention, extreme overloads caused by most air conditioning and refrigeration equipment operation could tax the electrical distribution system to the point where a permanent brown-out state could exist over much of the power company distribution network.
Locations at ends of long electric distribution lines may experience chronic Brown-out conditions due to line loss. Intermittent heavy loads on this trunk circuit may cause the Brown-out effect to fluctuate with the load.
Installations using ship-board or temporary power sources are especially prone to operation in a Brown-out mode. Usually of limited capacity, it is quite easy to overload the power source, giving rise to permanent Brown-out. (Permanent Black-out, if users are not careful).
What are some common effects of Brown-outs? Brown-outs are the mother of all sorts of Bad Stuff.
Power supplies in some electronic equipment may fall out of regulation. Errors, due to erratic power supply performance, may creep into computer operations.Other electronic equipment may function poorly - or not function at all.
Marginally performing devices (electronic or electric) will probably cease operation entirely.
Motors will overheat. Some motor types will slow down.
Electrical interference will greatly increase. Increased interference may affect computer and communication operations.
Off-line UPS units (the vast majority of lower cost units) continuously cycle between power line and internal battery operation. UPS batteries (generally sized to provide only 5 - 10 minutes back-up) will soon be discharged, unable to generate additional Back Up power. You are out of business. If system has not been shut-down, the entire system (UPS & computer) may snap back to life when power rises slightly, only to again shut down when the power line voltage falls back into the Brown-out zone. Such "ON-OFF" operational cycling is unhealthy for UPS, batteries and connected electronics. For Brown-out correction see our Voltage Regulator Page.
Spikes generated by electrical machinery also greatly increase. Air conditioners, refrigerators and other motorized devices generate local spikes. Industrial machinery (often miles away) create additional spikes which may find their way unto the electrical distribution system, and into your sensitive, valuable equipment.
Oct 25, 2007 | Samsung RS2630SH Side by Side Refrigerator
Electricity went out in town, tv won't turn back on.
On this type of problem, the first thing I check is the AC line fuse on the power supply. Follow the Ac plug wire to the power supply board and where it plugs in, you will find the fuse. If: Then: It checks bad. Replace it. It goes out again. Call a Servicer. It is good. Check for the five volts that goes to the Main PCB. No five volts, change the power suppy (SMPS) Five volts is there, more than likely the Main needs replaced and SMPS. For a Samsung Servicer in your area: 1-800-SAMSUNG
Aug 18, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
WON'T POWER UP
I had the LCD repaired. It turns out that the power supply went out. It cost me a few hundred bucks but it was worth the repair rather than buying a new one for 3x as much.
May 27, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Polaroid TDX-02610B LCD TV Logo
724 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
