Zanussi fx1465 washing machine drum not turning.
Takes on water but drum does not turn. if rinse mode selected drum rotates a few times then stops .cleaned pipes and filters.
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
How do I set spin only for Zanussi Lindo100 ZWF 71263W/71463W washing machine?
Spin
With this option you can change the default spin speed.
The indicator of the set speed comes on. Additional spin options:
No Spin
• Set this option to deactivate all spin phases.
Only the drain phase is available.
• The related indicator comes on.
• Set this option for very delicate fabrics.
• The rinses phase uses more water for some
washing programmes.
Rinse Hold
• Set this option to prevent the laundry creases.
• There is a water in the drum when the programme is completed.
• The drum turns regularly to prevent the laundry creases.
• The door stays locked. You must drain the
water to unlock the door.
untitled-pqbhbvgkecedzsp304arfp23-2-0.jpg Dado
Jan 18, 2018 | Zanussi Washing Machines
I have a Zanussi fj1254 w. It was making a high pitched squeel when it was spinning. No when I turn it on water goes in but the drum does not turn. It turns freely when rotated by hand. i have checked the...
Possible that the drive output to the drum is not there and so there is no voltage when the cycle come to the spin mode.
Check for fault in the drive, capacitor to the motor.
Jan 21, 2013 | Zanussi FJ1254W Front Load Washer
Wash machine - DST10146P Problem - After switch on and without any load in the drum, the kgMODE indicator appear, and the level load indicator starts blink the 10% levels from the mini to the MAX. The LED...
THIS MAY be your defective part!
BE VERY careful handling this switch because it's quite delicate!
1885374 "PRESSURE SWITCH" $89.68
Use THIS LINK:
http://spares.bigwarehouse.com.au/index.php?cPath=64618_64688_109010
These YOUTUBE video MAY help you!
Here is another YOUTUBE that discusses "Pressure Switches"... and that MAY be your problem. KNOW this is general information and not specific to your Hoover!
Diagnosing Washing Machine Pressure Switch Problems
How to Resolve Pressure Switch Problems in Washing Machine
Hoover and Candy Washing Machine Error Codes
TROUBLESHOOTING Link:
Dynamic Model No DST10146P 80 Product Code 31003253
Another snip-it:
..."Kg MODE Indicator". On Cotton and Synthetic cycles, during the first 4 minutes of the cycle the intelligent sensor will weigh the laundry and adjust the cycle time, water and electricity consumption accordingly. ...
More: The intelligent KG Mode sensor weighs the laundry and adjusts the cycle time, water and electricity consumption to suit the size of the load. This gives you the optimum consumption even if you are only washing one shirt.
During the first minutes of the cycle, the "Kg MODE" indicator remain on while the intelligent sensor will weigh the laundry
• Through every wash phase "Kg MODE"
allows to monitor information on the wash
load in the drum and in the first minutes
of the wash it:
- adjusts the amount of water required;
- determines the length of the wash cycle;
- controls rinsing according to the type of
fabric selected to be washed it;
- adjusts the rhythm of drum rotation for
the type of fabric being washed;
- recognizes
the presence
of lather,
increasing, if necessary, the amount of
water during rinsing;
- adjusts the spin speed according to the
load, thus avoiding any imbalance.
Dec 25, 2017 | Hoover Washing Machines
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
Drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
May 17, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Jan 29, 2009 | Washing Machines
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
