Question about HP iPAQ 614 Business Navigator 2.8-tft With Mobile (v6.0) Professional Smartphone
Hp ipaq business navigator on charge red light is blinking will not power on
  • Anonymous May 14, 2009
    Same here
The problem is the battery, change it (buy a new one) and it will work again.
Posted on Aug 18, 2009
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and...
its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Mar 12, 2017 | HP iPAQ rx1950 Pocket PC
I have forgotten my password for my hp ipaq to unlock it. plz help
Hi pls i have forgotten my password of my hp ipaq the seria number is TWC5500GRC pls i really need your help,my regards
Mar 27, 2011 | HP iPAQ 614 Business Navigator 2.8-tft...
I have a HP Ipaq H6340. I just got it from a
seem like all we get here are dead Ipaq.
why are you messing with this old device?
try a new battery, oops that costs money.
as does repairs on a device that has zero value.
why not mess with and old android phone, that has value.
ask here, be like only one playing Ipaq now.
https://h30434.www3.hp.com/
May 17, 2017 | HP iPAQ H6340 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Password for my ipaQ 614c
how do I unlock a hp ipaq 614 business navigator
Mar 14, 2009 | HP iPAQ 614 Business Navigator 2.8-tft...
Ipaq rx3115 frozen
Red LED light means a major problem at the charging of the battery.
You have several options to repair it:
1. Leave several hours the PDA with not battery and unplugged from the AC power adapter, then put the battery and leave charging it.
It's more likely that the red light will appears again, but leave plugged it. Sometimes will start charging and blinking with orange color after 30 minutes or so. After that, it will work normally.
2. Use other good working battery to test it.
3. If the above two steps fail, then there is a good chance that the mainboard has a problem, and needs to be fixed or replaced.
Best regards,
Jan 25, 2008 | HP iPAQ RX3115 Pocket PC
Hp ipaq h6315
If it is blinking red, it means that your battery is having issues. Try replacing the battery and see if it fixes the problem.
Dec 03, 2007 | HP iPAQ h6315/h6365 Pocket PC
HP iPAQ doesn't turn on
Failed battery pack most likely.
Jul 11, 2017 | HP iPAQ hw6510 Smartphone
HP iPAQ 614 Business Navigator 2.8-tft With Mobile (v6.0) Professional Smartphone Logo
1,129 people viewed this question
Top HP Cell Phones Experts
Bill Boyd
D. E. Hev
Andrew Taylor
Andrew Taylor
Are you a HP Cell Phone Expert? Answer questions, earn points and help others
