Question about Dualit Coffee Makers & Espresso Machines
Dualit 84009 Coffee machine - burnt plastic taste???
My Dualit 84009 Coffee machine's steam wand makes the milk taste and smell like burnt plastic???
The water is also like this when I use the espresso maker part.
Any Ideas what the problem is, it has happened in the past then gone away but now seems it is back for good.
help!
3 Suggested Answers
  • 2039 Answers
SOURCE: Coffee tastes burnt/No steam for froth
so i guess our expresso you dont have that creamy topping that lack pressure descalcify not with vinegar remove caicium in chunks have a chance of blocking everything descalcifier solution melt the calcium 1part solution 1 part water fill the water with solution open the valve if some come out close it leave the solution in it for 15 minute repeat untill empty rinse very good cheers
Posted on Feb 03, 2008
I don't know about the burning business but I had the same problem with the steam wand. the first thing I did to solve this problem was to take small object like a needle or safety pen and insert it into the base of the steam wand. (I have feeling that most problems related to the steaming wand are due to deposits clogging the wand itself.) After I cleared out as best I could I used vinegar and water to help remove any calcium deposits. Sure enough, after inserting the needle into the wand steam began to flow again.
Posted on Nov 02, 2008
My steamer wand has an awful odor everytime I try to steam something! I have cleaned it (even soaked in baking soda!) and the problem won't stop. Anyone else have this problem?
This is a common problem for the commercial espresso machines, Due to lack of cleaning of the steam wand after they finish frothing milk.
The milk flows back to the boiler and the water gets contaminated with milk.
Does the steam smells like rotten milk? If the answer is yes, you have contaminated water and or lines.
If not may be there is a lot of IRON in the water.
Run a descale cycle.
After you are done frothing milk, wipe the steam wand with a wet towel and open the steam valve for 2 seconds, close it and that's it.
Jan 15, 2011 | Saeco Starbucks Sirena Espresso Machine
When I steam my milk it tastes burnt and there is a strong burning odor.
The boiler needs to be cleaned, it is contaminated with milk. Check the water from the tea spicket, if it smells funny or it is discolored then the boiler is contaminated, if not then the problem is at the steam wand and steam valve.
Jan 11, 2011 | Astoria Compact CKXE Espresso Machine
Why does steam wand on dualit espresso leak
The wand can leak if the rocker switch is not in the UP position.
In MIDDLE position it will try to deliver hot water.
In DOWN position it will try to deliver steam.
The thermoblock in this unit is actually a 3-way valve, of which two positions route water from the boiler directly to the wand. The 3rd position (UP) routes hot water (but not steam) from the boiler to the group head.
Try holding the switch in the UP position by hand when making coffee. If the machine still pushes water through the wand then you will have to replace the switch inside the machine that is activated by the rocker, or the valve it operates.
Please let me know how it goes.
graham dot r dot leach at gmail dot com
Oct 01, 2010 | Dualit Espresso 889 Espresso & Coffee...
Steam smells odd and affects milk taste.
The boiler is contaminated with milk and needs to be descaled and cleaned.
Jul 31, 2010 | Astoria Argenta SAE-2 Espresso Machine
Burnt smell is coming from steamer wand
Boiler is contaminated with milk, check the water from the tea valve, if it smells the same or has swimmers, boiler needs to be descaled, if no floaties then removes steam wand and soak in purocaff for a few hours, then clean. Always flush ssteam wand before and after every drink.
Mar 04, 2010 | Nuova Simonelli Mac 2000 I Group Espresso...
STEAM PROBLEM
Does the steam itself smell, or just the milk. If yes on the steam run the descale again. If no on steam then check the perfect cream wand the black plastic arm connected to the steam wand, dissamble and clean, make sure all the holes are clear.
Mar 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
The steam coming out of my espresso smells burned
Try descaling amchine to clean boiler.
Mar 12, 2009 | Saeco VIA Venezia
Feb 26, 2008 | Mr. Coffee ECM10
Feb 03, 2008 | Mr. Coffee ECM20 Espresso Machine
Coffee Makers & Espresso Machines Logo
114 people viewed this question
Top Dualit Coffee Makers & Espresso Machines Experts
Hjalmer Lamminen
Hjalmer Lamminen
ray gallant
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Dualit Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
